A question about fluid pressure
The discussion focuses on calculating the change in volume and density of water as it descends to the bottom of the Mariana Trench, approximately 11 km deep. The pressure at this depth is about 1.13 x 10^8 Pa. The correct answers are a change in volume of -5.4 x 10^-2 m^3 and a density of 1.09 x 10^3 kg/m^3 at the ocean floor. The key to solving these problems lies in understanding the compressibility of water, specifically utilizing the bulk modulus of water, which is 0.21 x 10^10 Pa.
  • Understanding of fluid pressure and hydrostatic pressure equations
  • Knowledge of water's compressibility and bulk modulus
  • Familiarity with density calculations and volume changes under pressure
  • Basic algebra for rearranging equations and solving for unknowns
  • Research the properties of water under high pressure, focusing on compressibility
  • Study the equations of state for fluids, particularly in relation to density changes
  • Learn about the bulk modulus and its applications in fluid mechanics
  • Explore hydrostatic pressure calculations in various fluid scenarios
Students studying fluid mechanics, physicists interested in oceanography, and engineers working with high-pressure fluid systems will benefit from this discussion.
rkrk
The deepest point in the ocean is in the Mariana Trench about 11 km deep. The pressure at the ocean floor is huge, about 1.13*10^8 Pa.
a) calculate the change in volume of 1.00 m^3 of water carried from the surface to the bottom of the Pacific.
b) The density of water at the surface is 1.03*10^3 km/m^3. Find its density at the bottom.
I am not really sure how you could approach this problem, as the answers are supposed to be:
a) -5.4*10^-2 m^3
b)1.09*10^3 kg/m^3
I first tried to use the equation: P= P(atmospheric) + (density)(g)(h) to find the density at the bottom of the ocean. then I figured I could set a proportion between the volumes and densities at the surface and at the bottom to find the volume at the bottom. But the density I get for the bottom is not 1.09*10^3, the actual right answer.
It seems that you must have some relevant relation for the compressibility of the water. That is the only thing that will make the water denser at depth. We normally think of water as incompressible, but it sounds like at high enough pressures, a small amount of compression does occur. So where would you look to find the compressibility of water?
BTW, there are some typos in what you typed above in the units. Like in your statement for (b) where you say a density has units of km/m^3.
Thanks
Oh yeah, I forgot about that. I found out the compressibility of water (the bulk modulus) which was 0.21 *10 ^10 Pa. Using the equation delta(P)=-B*[delta(V)/V], where B was the bulk modulus and rearranging for delta(V) I got the right answer.
  • · Replies 16 ·
11K
