Required velocity for a stable orbit?
The discussion revolves around calculating the velocity required for a stable orbit between two objects of different masses, specifically focusing on the relationship between distance and orbital velocity.
  • Participants explore the concept of orbital velocity and its dependence on the masses of the objects and their distance apart. Some question the conditions under which stable orbits can be achieved, while others reference the conservation of angular momentum and gravitational forces.
There are various interpretations of the problem, with some participants providing equations and insights into the dynamics of orbital motion. A specific equation for critical velocity has been mentioned, but there is no explicit consensus on the best approach to the problem.
Some participants express confusion about the classification of the thread, indicating it may not fit typical homework parameters. Additionally, there are assumptions about the relative sizes of the objects involved in the discussion.
qwedsa
Say we have two objects. One is at the origin with mass = 1kg, the other is X meters away with mass 0.1kg
Is there a way to calculate the velocity required to form a stable orbit, depending on the distance of the smaller object?
Are you trying to calculate the orbital velocity, mr. qwesda?
^hey complex. i didn't know there was the term 'orbital velocity'
googling this term should give me everything i need, thanks
Hey guys ;) Depends on the size of the objects. If the objects are both points, then any sideways velocity will be enough for them never to collide because the conservation of angular momentum prevents it.
The bigger the objects, the more tangential velocity they need, because they can't have their centres get closer than the sum of their radii, that would be a collision.
Is this not the case of equating circular motion forces with gravitational attraction forces...
someone on another forum (BL) gave me this handy equation:
crit_velocity = sqrt( 2*G*m1 / dist )
where m1 is the mass of hte heavier object. note, this only works if hte mass of the lighter object is much much lighter than the heavier object
if the velocity of the lighter object is less than the critical velocity, then it will form an orbit. if it's greater than the crit_vel, then it will fly off forever
dont know why this was moved here, it wasnt hw, I'm not even in physics
  • · Replies 17 ·
  • · Replies 32 ·
