Probabilities: Estimating the probability of overlapping
This discussion focuses on estimating the probability of overlapping selections from two bins containing N numbered balls, where the selection probability for each ball is defined by P(ball-k-selected) = k/SUM(1:N). The simple case calculates the probability of selecting the same numbered ball from both bins as SUM(k=1:N) (P(ball-k-selected)^2). The complex case extends this to selecting m balls from each bin and determining the probability of at least one pair of balls sharing the same number, assuming stable selection probabilities and combinations of subsets.
  • Understanding of probability distributions and selection probabilities
  • Familiarity with combinatorial mathematics, specifically combinations C(n, m)
  • Knowledge of set theory, particularly the notation for sets and subsets
  • Basic grasp of the concept of selection without replacement
  • Research advanced probability theory, focusing on overlapping events
  • Study combinatorial probability and its applications in real-world scenarios
  • Explore the implications of selection without replacement in probability calculations
  • Learn about different probability distributions and their properties
Mathematicians, statisticians, data scientists, and anyone interested in probability theory and combinatorial analysis.
jksacc
Hi all
I recently ran into this problem:
I have two bins. Each bin contains N numbered balls, from 1 to N.
For both the bins, the probability of the ball numbered k to be
selected equals to P(ball-k-selected)=k/SUM(1:N) (in other versions
this can be any given probability distribution)
Simple case:
Having selected 1 ball from the first bin, and 1 ball from
the second bin, i want to find the probability of the ball
having the same number.
If i am correct, the probability for this is SUM(k=1:N) (P(ball-k-selected)^2).
Complex case:
Having selected m balls from the first bin, and m balls from
the second bin, i need the probability of holding at least
one pair of balls with the same number at the end of the
experiment.
Assumption: The selection is without replacement. However, for
simplicity we can assume that the probability of a ball to be selected
remains stable during the experiment, and is given by
If something is not clear, please let me know.
Thanks in advance for any contributions!
Denote integers with lowercase and sets with UPPERCASE. The set of balls in bin i is Ni.
There are C(n, m) = n!/(m!(n-m)!) combinations (subsets) that you can draw from either bin.
Let S1 be a subset of m balls from the 1st bin. Let S2 be the corresponding subset from the 2nd bin. How many subsets of m balls can you form out of the set of the remaining balls in the 2nd bin, S2' = N2\S2? The answer is s2' = |S2'| = C(n-m, m). That's the answer to the question, "for a given S1, how many disjoint subsets of the same size are there?" Since there are C(n,m) ways to construct S1, there are C(n,m)C(n-m,m) ways to construct two disjoint subsets, each with m elements.
Now you need to calculate the probability of obtaining these disjoint subsets.
  • · Replies 29 ·
  • · Replies 18 ·
