What is the magnitude of the total momentum
The total momentum of a system consisting of a golf ball and a baseball is calculated using their respective masses and velocities. The golf ball, with a mass of 4.5×10^-2 kg moving at 8.65 m/s in the +x-direction, has a momentum of 0.38925 kg*m/s in the positive x-direction. The baseball, with a mass of 0.145 kg moving at 7.2 m/s in the -y-direction, has a momentum of 1.044 kg*m/s in the negative y-direction. The total momentum vector is 0.38925i - 1.044j, resulting in a magnitude of approximately 1.114 kg*m/s and an angle of 70 degrees measured from below the x-axis.
  • Understanding of momentum calculation using the formula p=mv
  • Knowledge of vector notation in physics
  • Familiarity with the Pythagorean theorem for vector magnitude
  • Ability to use trigonometric functions, specifically arctangent, for angle calculation
  • Study vector addition in physics to understand momentum in multiple dimensions
  • Learn about the conservation of momentum in collision scenarios
  • Explore the application of trigonometry in physics problems
  • Review examples of momentum calculations involving different mass and velocity combinations
Students studying physics, particularly those focusing on mechanics, as well as educators looking for examples of momentum calculations in two-dimensional systems.
lollypop
hi, i did the first part of this problem but on
the second I'm stuck.
A golf ball with mass 4.5×10^-2 kg is moving
in the +x-direction with a speed of 8.65 m/s ,
and a baseball with mass 0.145 kg is moving in
the -y-direction with a speed of 7.2m/s .
--What is the magnitude of the total momentum
of the system that consists of the two balls?
(i got for this one 1.06 kg*m/s using p=mv for
each ball and adding them )
--What is the direction of the total momentum
Express your answer as an angle measured from
below the x-axis (for this part i tried doing
arctangent but the answer is not right)
any help is good, thanks.
Write the two momentum vectors in "component" notation:
"A golf ball with mass 4.5×10^-2 kg is moving
in the +x-direction with a speed of 8.65 m/s " so it's momentum is 4.5x10^-2*8.65= 0.38925 in the positive x direction:
0.38925i+ 0j
(i is the unit vector in the positive x-direction and j is the unit vector in the positive y-direction.)
" baseball with mass 0.145 kg is moving in
the -y-direction with a speed of 7.2m/s" so its momentum is 0.145*7.2=
1.044 in the negative y direction:
0i- 1.044j
The total momentum vector for the system is the sum of those two vectors: 0.38925i- 1.044j
You can NOT just add the raw values- they are not in the same direction! (and I don't see how you could have gotten "1.06" in any case.)
The magnitude of the momentum is the "length" of that vector which is, by the Pythagorean theorem, √(0.389252+ 1.0442)= 1.114 kg m/s approximately.
Yes, you should be able to find the angle using arctan:
The vector diagram should give you a right triangle with legs of length .38925 and 1.044 (and, of course, hypotenuse of length 1.114).
The tan(θ)= .38925/1.044= .3728 so θ= 20.5 degrees (make sure your calculator is in "degree mode" if you want angles in degrees).
Now, check your diagram to see where that angle is! I have intentionally done the "wrong" angle so you will need to determine what the angle is measured from "below the x-axis".
thans you, i did get the right angle after ur explanation, it was 70 degrees, thanks again! :)
  • · Replies 19 ·
