Calculating Velocity and Acceleration Along a Parabolic Path
The discussion focuses on calculating velocity and acceleration for a point moving along the parabolic path defined by the equation x = y²/6, with a constant vertical velocity of 3 in/s. When x = 6 in, the corresponding y value is 6, and the time taken to reach this point is 2 seconds. The acceleration is determined to be 0 due to the constant velocity. The key to solving for velocity and acceleration lies in differentiating the position equations with respect to time using the chain rule.
  • Understanding of calculus, specifically differentiation and the chain rule.
  • Familiarity with kinematic equations, particularly for constant velocity motion.
  • Knowledge of parabolic equations and their properties.
  • Basic understanding of differential equations.
  • Study the application of the chain rule in calculus for related rates problems.
  • Learn how to differentiate parametric equations with respect to time.
  • Explore kinematic equations in two dimensions, focusing on velocity and acceleration.
  • Investigate the use of differential equations in motion analysis along curves.
Students and professionals in physics, engineering, and mathematics, particularly those interested in motion analysis along curved paths and the application of calculus in real-world scenarios.
glid02
Hey guys,
Here's the question:
A point A moves along a curve with the equation x = y^2/6 and is elevated in the y direction at a constant velocity of 3 in/s. Calculate the velocity and the acceleration when x = 6 in.
So I solved for y and y=sqrt(6*x) and when x=6 y=6.
Since the point is moving at a constant velocity of 3 in/s it takes 2 seconds to get to 6 in.
I plugged this into y=y0+vt+1/2at^2 and got a=0 which is obvious since it's moving at a constant velocity.
Here's where I'm stuck, I tried the same equation with x. I think I may be able to solve for v and a by solving the differential equation but I don't think that's what I'm supposed to do.
It seems like I'm supposed to differentiate the positions with the equation giving but I'm not sure how I'm supposed to do that because when differentiating y with respect to x the derivative of y=sqrt(6*x) is 0 and the derivative of x=y^2/6 is also 0.
Any help would be great. Thanks a lot.
You have a very important piece of information: dy/dt is constant...
and you are asked to find the velocity and accelaration when x = 6...
since dy/dt and d^2y/dt^2 is known( how do you get the accelaration in the y direction?)
, all you need is dx/dt, and d^2x/dt^2, right?
differentiate x=y^2/6 over t on both side... you will have dx/dt in terms of dy/dt and y...
differentiale it once more, you will get d^2x/dt^2, which is a constant...
EDIT: One more hint.. Use chain rule: [tex]\frac{dy^2}{dt} = \frac{dy^2}{dy}\frac{dy}{dt} = 2y\frac{dy}{dt}[/tex]
  • · Replies 40 ·
