Which Diode is Best for Charging and Maintaining Capacitor Charge?
  • Thread starter Thread starter pumas
    Capacitor Diode
The discussion centers on selecting the best diode for charging and maintaining a capacitor's charge. The diode with the smallest reverse leakage current is identified as the optimal choice, as it allows the capacitor to discharge more slowly. While Schottky diodes exhibit higher leakage currents, they also have a lower forward voltage drop (~0.2V) compared to pN junction diodes (~0.7V), which can influence charging efficiency. Ultimately, the diode with the smallest leakage current is recommended for maintaining charge over time.
  • Understanding of diode types, specifically Schottky and pN junction diodes
  • Knowledge of reverse leakage current and its impact on capacitor discharge
  • Familiarity with forward bias operation of diodes
  • Basic principles of capacitor charging and discharging
  • Research the characteristics and applications of Schottky diodes
  • Explore the effects of reverse leakage current on capacitor performance
  • Learn about forward bias operation in diodes and its implications for charging
  • Investigate different capacitor types and their discharge behaviors
Electrical engineers, electronics hobbyists, and anyone involved in circuit design or capacitor applications will benefit from this discussion.
pumas
Hello,
In lab the reverse leakage current of 4 different diodes was measured. Then ranked from smallest to biggest. Then we are asked to decide which diode would be most suitable for charging up a capacitor and allowing the capacitor to keep its charge for the longest period of time?
I think it would be the one with the smallest current because it would allow the capacitor to discharge slower. However, it would take longer to charge. Am I right?:confused:
Yes, the one with the smallest leakage current will discharge the capacitor the slowest. As for the charging time, it has nothing to do with the leakage current, because when you charge the capacitor, the diode operates in the forward bias region.
Now it's true that the diode with the biggest leakage current might happen to be a Schottky diode (because they have bigger leakage current than pN junction diodes), and the Schottky diode has a lower forward voltage drop at same forward currents: ~0.2V compared to ~0.7V for a pN junction diode, which means that the capacitor will be charged to a higher voltage and thus take a longer time to discharge.
But given that you only know the leakage currents, you assume the diodes to be of the same type and the correct answer is the diode with the smallest leakage current.
Thanks for your help :smile:
