How Does a Wall Collision Affect a Ball's Momentum and Contact Time?
  • Thread starter Thread starter dnt
The discussion revolves around a physics problem involving a ball colliding with a wall, focusing on momentum, contact time, and the effects of forces during the collision. The subject area includes concepts from mechanics, specifically momentum conservation and impulse.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the conservation of momentum and its relevance to the collision, questioning whether momentum is conserved after the collision with the wall. They discuss the relationship between the force exerted by the wall and the ball's change in momentum. There is also consideration of how to calculate the vertical velocity component and the time of contact with the wall.
Participants are actively engaging with the problem, sharing their calculations and reasoning. Some have offered guidance on applying the impulse-momentum theorem and considering the effects of gravity during the collision. There is an ongoing exploration of the implications of the force direction on the vertical velocity component, with no explicit consensus reached yet.
Participants note potential confusion regarding the impact of gravity on the vertical velocity during a short collision time, as well as the accuracy of their calculations. There is acknowledgment of the problem's constraints and the need to clarify assumptions made during the analysis.
dnt
A .30 kg ball with initial velocity of 21i - 1.3j colldes with a wall. The wall exerts a force of -155i N on the ball and its final horizontal component of velocity is -11i m/s.
(a) Find the vertical velocity component.
(b) Find the total change in momentum.
(c) How long was the ball in contact with the wall?
change in momentum = impulse = Ft
I think my main problem is I am not sure if this is a conservatoin of momentum problem or not - is momentum conserved after the collision with the wall? I am having a hard time relating the 155 N force applied from the wall to the ball.
I know that if I can find the vertical component of velocity after hitting the wall, I can easily find the change in momentum (part b) by:
m (vf - vi) where vf and vi are the overall resultant velocity vectors.
and i know that if i get that i can set it equal to Ft to find the time in contact with the wall (part c) but i cannot figure out part a. can someone please help. thanks.
Strictly speaking momentum is conserved, but that's not very useful to solve the problem, because the change of momentum of the ball equals the change of momentum of the wall plus the earth!
You said (correctly) change of momentum = impulse = Ft. Apply that equation to the ball.
Force and momentum are vector quantities. What does the question say about the direction of the force on the ball?
change in momuntum = m(change in v)
which is (.30 kg)(vf - 21.04 m/s) = (-155N)t
{i got the 21.04 m/s by using pythagorean theorem to 21i - 1.3j and found the resultant vector...correct?}
anyways, now i have two variables. i know if i get vf, then i can solve for t easily. but i cannot get vf! still stuck...
since it is negative the force on the ball is in the OPPOSITE direction compared to when the ball struck the wall.
doing some more thinking about it...am i getting closer:
m(vf-vi)=Ft but perhaps i should consider it in the horizontal only...
(.03)(-11 - 21) = (.155)(t)
t = .00619 seconds?
is that right?
but i still cannot figure out the final vertical velocity (part a). can i use one dimensional kinematics to find it (using vertical components only)?
vf = vi + at
vf = (1.3j) + (9.81)(.00619 sec)
vf = 1.3608j m/s
any help is much appreciated. I am really trying to get this.
Your decimal points are sliding around so the answer is not right, but that is essentially it. Now what direction have you assumed the force is acting in? What does that say about vertical change in velocity?
i assumed the direction was acting in the horizontal direction so it should not affect vertical velocity. however, gravity should make it increase. hence my confusion.
It would. The usual line is that the collision time is short enough that the correction from gravity is not important. In this case you could make a point that it is (it's a SLOW collision). Not really the point of the exercise though I don't think...
are you implying that vertical velocity isn't going to change because of such a short time period?
No. I'm saying it will change (and in this case by a fair amount compared with vf). I am saying I don't think that correction is the point of the exercise. As for the final horizontal velocity - that was given to you as part of the problem statement. How could you 'figure it out'?
ok tried to fix it:
HORIZONTAL: (.03)(-11 - 21) = (-155)(t)
t = .0619 seconds
VERTICAL:
vf = vi + at
vf = (1.3j) + (9.81)(.0619 sec)
vf = 1.907j m/s
so i solve for time BEFORE solving for final vertical velocity? is this correct?
i know that's why i edited it out - i overthought the problem and i confused myself! i then realized what i typed and took it out. sorry.
Looks fine. Make it clear that vf has been corrected for gravitational acceleration during the collision. That may not be part of the expected answer.
you mean for the 1.907 m/s part? how do i make it clear? isn't showing my work sufficient?
btw thanks for the help!
Sure. Clearly showing work is sufficient. You're welcome - but I didn't help that much.
  • · Replies 19 ·
