Converting Complex Numbers to Polar Form: A Mathematical Explanation
The discussion revolves around converting complex numbers to polar form, particularly in the context of electronic engineering. Participants explore the mathematical methods for this conversion, addressing both the theoretical aspects and practical challenges faced by one participant who lacks a calculator capable of performing the conversion.
  • Homework-related
  • One participant expresses difficulty in converting complex numbers to polar form due to limitations with their calculator and seeks mathematical guidance.
  • Another participant explains the process of converting a complex number from rectangular form (x + yj) to polar form (R(cosθ + jsinθ)), detailing the calculation of the modulus R as √(x² + y²).
  • The second participant provides a specific example using the numbers 3.76 and 4.78 to demonstrate the conversion process, confirming the angle derived from the cosine and sine values.
  • A third participant suggests looking up resources online for further clarification on the conversion process and emphasizes the trigonometric relationships involved.
  • A later reply acknowledges the assistance received and indicates that the participant is beginning to understand the relationship between the real and imaginary components.
Participants generally agree on the mathematical principles involved in converting complex numbers to polar form, but there is no consensus on the best method for someone without a suitable calculator. The discussion remains open to further questions and clarifications.
Some participants reference specific values and calculations, but the discussion does not resolve all potential uncertainties regarding the conversion process or the use of calculators.
Paddy
Firstly I do apologise, because this question is got more to do with the mathematical side of Electronic Engineering, because my mathematical classification is not that good I don't know where I would put this question on the mathematics section, if any of the moderators or whoever can, wants to move it there, I do apologise.
I am having a bit of problem with my calculator, unlike many other people in my class, my calculator can't exchange complex numbers to polar form, so I have to do it by using some mathematics.
I know how to change from polar form back to complex notation, so for example imagine a voltage of 6.08 |51.8*.
I believe that 6.08cos51.8 will get you the real component and 6.08sin51.8 is J, so in J-notation ==> 6.08 |51.8* = 3.76 + J4.78
I haven't made up these difficult numbers, but I have taken them from a class example, I suppose the method is correct because that was the answer checked by the teacher.
However I do not know how to exchange a number back to polar form, I think my best option would be buying a better calculator, but I would appreciate if someone could show me by mathematical terms, Thank You.
Let's consider a general case first, and consider the complex number x+yj, where x and y are real numbers. Now, we want to express this in polar form, which is R(cost+jsint). Here, R is the modulus of the complex number (I'm not sure whether you're familiar with this) but it is simply defined as √(x2+y2).
So, to move onto your example, we want to write 3.76+4.78j in the form R(cost+jsint). First calculate the modulus of the complex number; R=√(3.762+4.782)=6.08. Now, we factor this out of the complex number, to give 6.08(0.6181+0.7026j). This is nearly in polar form. The final step is to take cos-1(0.6181) and sin-1(0.7026). You will find that these are both 51.8, and so we have the number expressed as 6.08(cos(51.8)+jsin(51.8)), which has real part 6.08cos(51.8) and imaginary part 6.08sin(51.8), as you state in your post.
Hope this helps!
No worries, I googled polar to rectangular conversion complex numbers, and got lots of good hits. Here's the first one:
http://www.allaboutcircuits.com/vol_2/chpt_2/5.html
Basically just think of the trigonometry involved, with an x-y graph where the +x axis is the Real axis, and the +y axis is the Imaginary axis. We use the prefex j (or i in non-EE areas) to denote the Imaginary component in the rectangular form of complex numbers, or as a prefex to the angle (in radians) in complex exponential form (which is another notation for the polar form).
If you have any other questions about this topic after reading the tutorial, please feel free to repost in this thread.
Dang, cristo beats me to the punch again!
Thank you So, So much.
I was along the right lines, but the relationship between the imaginary and real numbers confused me a bit.
Starting to make sense and I am starting to get the idea. Thank you.
