Convert 40 Inches Water to PSI - Thermodynamics Help
  • Thread starter Thread starter wub1098
    Thermodynamics
The discussion focuses on converting a pressure measurement of 40 inches of water to pounds per square inch (psi). The conversion factor established is that 1 inch of water column is equivalent to 0.0361 psi. Therefore, 40 inches of water translates to approximately 1.444 psi. This conversion is crucial for applications requiring precise pressure measurements in various engineering fields.
  • Understanding of pressure measurement units
  • Basic knowledge of fluid mechanics
  • Familiarity with manometer principles
  • Ability to perform unit conversions
  • Research the principles of manometers and their applications
  • Learn about fluid statics and pressure calculations
  • Explore the conversion of other fluid column measurements to psi
  • Study the impact of temperature on fluid density and pressure readings
Engineers, physics students, and professionals in fields requiring accurate pressure measurements will benefit from this discussion.
wub1098
A manometer measuresa pressure difference as 40 inches of water. What is this pressure difference in psi?
solution with short ecplanation would be very appreciated thanks
No, show some work.
  • · Replies 26 ·
  • · Replies 30 ·
  • · Replies 24 ·
