:Determining Flow Rate/Velocity of Fluid in Low Vacuum
The discussion focuses on determining the flow rate and velocity of a fluid transitioning from atmospheric pressure to a low vacuum. The primary tool referenced is Bernoulli's equation, which is essential for calculating fluid dynamics in this context. The user seeks clarification on which specific form of Bernoulli's equation to apply for calculating the velocity and flow rate of a fluid forced up a pipe by atmospheric pressure due to a partial vacuum. Understanding the application of Bernoulli's equation is crucial for solving this problem effectively.
  • Understanding of Bernoulli's equation and its applications in fluid dynamics
  • Basic knowledge of fluid mechanics concepts
  • Familiarity with pressure differentials and their effects on fluid movement
  • Ability to interpret and manipulate equations related to fluid flow
  • Study the specific forms of Bernoulli's equation relevant to flow in pipes
  • Research the principles of pressure differentials in fluid dynamics
  • Learn about the effects of atmospheric pressure on fluid behavior in low vacuum conditions
  • Explore practical applications of fluid flow calculations in engineering scenarios
Students in engineering or physics, fluid mechanics enthusiasts, and professionals involved in fluid dynamics applications will benefit from this discussion.
Idea04
How do you determine the flow rate or velocity of a fluid moving towards a low vacuum from atmospheric force pushing the fluid towards the low vacuum?
Bernouilli's equation.
I looked up the Bernouilli's equations, But I did't know which one to use. I would like to know the velocity and flow rate of a fluid be forced up a pipe by atmospheric pressure because of a partial vacuum.
Can you tell me which equation to look under. What category it would be under.
  • · Replies 19 ·
  • · Replies 61 ·
