Proving Bijections: Tau_1,2,3,4 on Q(sqrt(2), sqrt(3))
  • Thread starter Thread starter Gott_ist_tot
The discussion focuses on proving that the rational linear mappings tau_1, tau_2, tau_3, and tau_4 are bijections of Q(√2, √3). Each mapping is defined as a piecewise function, where tau_1 and tau_2 maintain the positive values of √2 and √3, while tau_2 maps √3 to -√3. The participant argues that these mappings are injective and surjective, demonstrating that each element in the codomain corresponds to a unique element in the domain. The conclusion emphasizes that all elements of Q(√2, √3) can be expressed in the form a + b√2 + c√3 + d√6, confirming the bijective nature of the mappings.
  • Understanding of rational linear mappings
  • Familiarity with piecewise functions
  • Knowledge of injective and surjective functions
  • Basic concepts of field extensions, specifically Q(√2, √3)
  • Study the properties of bijective functions in abstract algebra
  • Learn about field extensions and their applications in number theory
  • Explore piecewise function definitions and their implications in mappings
  • Investigate the implications of injectivity and surjectivity in linear transformations
Mathematics students, particularly those studying abstract algebra and field theory, as well as educators looking to enhance their understanding of rational mappings and bijections.
Gott_ist_tot
Sorry for no tex. When I previewed it it would just come up as not finding the images so I made it in ascii as well as I could.
Show that each of the rational linear mappings tau_1 tau_2 tau_3 and tau_4 is a bijection of Q(sqrt(2) sqrt(3))
These are meant to resemble piecewise functions.
...{ sqrt(2) |--> sqrt(2)
tau_1 : {
...{ sqrt(3) |--> sqrt(3)
tau_2 : {
...{ sqrt(3) |--> (-)sqrt(3)
The other two just makes the mapping of sqrt(2) go to the negative and the last one has both going to the negative
I seem to be able to argue it in words. I just do not think it is a mathematically correct method. I am new to the whole abstract aspect of math.
Tau_i where i = 1,2,3,4 are just a series of mappings of alpha |--> beta or alpha |--> (-)beta. In the cases alpha |--> beta alpha = beta. This means that if you map two elements x,y such that x =/= y you will get two elements of beta w,v such that w =/= v. Therefore if tau(x) =/= tau(y) w =/= v and it is injective. To prove surjective every element of beta has a value in alpha since the value in alpha equals the value in beta. Thus it is not restricted to any range of values.
I would use the same argument for the negative I don't know any special things I should look out for since I believe there is a number y such that x+y=0 where y is denoted as -x. The only problem I can see with this is that was for the reals and I am dealing with rationals. Thanks for any advice.
[itex]\tau_2[/itex] takes [itex]\sqrt{2}[/itex] into [itex]\sqrt{2}[/itex] and [itex]\sqrt{3}[/itex] into [itex]-\sqrt{3}[/itex]
Any number is [itex]Q(\sqrt{2},\sqrt{3})[/itex] can be written in the form [itex]a+ b\sqrt{2}+ c\sqrt{3}+ d\sqrt{6}[/itex]
(I'm going to call [itex]\tau_2[/itex] "f" since it is easier to type!)
Then [itex]f(a+ b\sqrt{2}+ c\sqrt{3}+ d\sqrt{6})[/itex]= [itex]f(a)+ f(b)f(\sqrt{2})+ f(c)f(\sqrt{3})+ f(d)f(\sqrt{2})f(\sqrt{3})[/itex]= [itex]a+ b\sqrt{2}- c\sqrt{3}- d\sqrt{6}[/itex].
  • · Replies 27 ·
