Calculating Expectation Values for x, x^2 in 1D Box
The discussion revolves around calculating the expectation values of position \( x \) and \( x^2 \) for a particle in a one-dimensional box, specifically in the quantum state represented by the wave function \( \Psi_n \). Participants are exploring the mathematical formulation and integration techniques necessary for these calculations.
  • Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the setup of the integrals for expectation values, with one noting the need to adjust integration limits to the boundaries of the box. There are mentions of using integration by parts as a potential method for solving the integrals. Some participants express confusion about the application of the multiplicative operator \( x^2 \) in the integrals and whether their approaches are correct.
The discussion is ongoing, with participants sharing their attempts and seeking clarification on their methods. Some guidance has been offered regarding integration techniques, but there is no explicit consensus on the correct approach or resolution of the problem.
Participants are working under the constraints of the problem as a homework assignment, which may limit the information they can share or the methods they can use. There is also a focus on ensuring the correct application of quantum mechanics principles in the context of the problem.
thenewbosco
Calculate the expectation values of x, [tex]x^2[/tex] for a particle in a one dimensional box in state [tex]\Psi_n[/tex]
[tex]\Psi_n = \sqrt{\frac{2}{a}}sin(\frac{n\pi x}{a})[/tex]
i formed the integral
[tex]\int_{-\infty}^{+\infty}\Psi ^2 x dx[/tex] as the expectation value of x. (Psi squared simply because this psi is not complex)
this gives [tex]<x>=\frac{2}{a} \int_{-\infty}^{+\infty}x sin^2(\frac{n\pi x}{a})dx[/tex]. The problem is i do not know a way to simplify this integral, similarly i have the problem when there is an x^2 in the integral.
any help would be appreciated
First, the limits of integration are the ends of the box, not infinity...(since psi is zero outside the box anyway)
To solve, try integration by parts. (BTW I just did the exact same problem!)
I am working on this same problem for x^2. Since x is just a multiplicative operator, shouldn't you just be able to put in x^2 in front of the sin term? It doesn't seem to give me the correct result.
Thanks
Thanks
Can I see your work? You may be making a computational error. You should be able to do that integral by integration by parts as well, just like the previous one. It just takes one more step.
I found your solution on another page G01, I'm still not sure what I was doing wrong though. It seems like my method should work. Any ideas?
What was your method? If you mean putting the x^2 in front of the sine term that should be fine. How did the solution you find solve it?
I am just calculating the actual values, so I'm letting my calculator due the integration. Could you explain the process to get to the correct integration?
So, for <x^2>, I should just be able to replace x with x^2 in front of the sin term in the last equation of the first post?
  • · Replies 30 ·
