Physics problem about springs PLEASE HELP
  • Thread starter Thread starter dardar22
    Physics Springs
The discussion focuses on calculating the spring constant and the period of oscillation for two different blocks suspended from springs. For the first scenario, a 2 kg block with an additional 253 g body stretches the spring by 2.5 cm, resulting in a spring constant (K) of 99.2 N/m. In the second scenario, a 1.8 kg block with a 221 g body stretched the spring by 3.8 cm, and upon removing the 221 g body, the period of oscillation can be determined using the derived force balance equations. The gravitational acceleration (g) is consistently used as 9.8 N/kg throughout the calculations.
  • Understanding of Hooke's Law (F = kx)
  • Basic knowledge of gravitational force (W = mg)
  • Familiarity with oscillatory motion and period calculation
  • Ability to manipulate algebraic equations for problem-solving
  • Learn how to derive the spring constant using different mass and displacement scenarios
  • Study the principles of simple harmonic motion (SHM) and its equations
  • Explore the effects of mass and spring constant on the period of oscillation
  • Investigate real-world applications of springs in mechanical systems
Students studying physics, mechanical engineers, and anyone interested in understanding spring dynamics and oscillatory systems.
dardar22
A 2 kg block hangs from a spring. A 253g body hung below the block stretches it a further 2.5cm. What's the spring constant? Use g=9.8N/kg. Calculate the value to 1 decimal place and use N/m as your unit.
AND
A 1.8kg block hangs from a spring. A 221g body hung below the block stretches it a further 3.8cm. If the 221g body is removed and the block set into oscillation, what is the period of the motion? Use g=9.8N/kg. Calculate the value to 2 decimal place and use second as your unit.
In order to get help, you should post an attempted solution.
Here is a hint: Write the force balance equation for a) just the first block and b) both blocks together. How can you then use these two equations to obtain an expression for k in terms of the known values?
for the second part, if I were to do it, I would set up a force balance equation (left side in terms of displacement x from the rest postion, right side in terms of acceleration = d^2x/dt^2) with initial conditons dx/dt(0)=0 and x(0)=-x1. This could then be solved, and the period of the solution can be obtained.
What a know/think!
number 1??
I THINK.. it is
we know F=KX & W=MG
since F=W, KX=MG
so K*d=2kg*G also K*(d+2.5cm)=2.253kg*G
so K=(2kg*G)/d also K=(2.253kg*G)/(d+2.5cm)
then (2kg*G)/d = (2.253kg*G)/(d+2.5cm)
we solve for d: (d+2.5cm)/d= (2.253kg*G)/(2kg*G)
G cancels out: (d+2.5cm)/d= 2.253kg/2kg
so 1+(2.5cm/d)= 2.253/2
2.5cm/d= 2.253/2-1
d= 2.5cm/(2.253/2-1)=
now that you have d and d+2.5cm
you can plug into equation F=KX or K=F/X which is K=MG/X
use K=MG/X
K=2kgG/d you know G and d so you have K which is spring constant.
K=99.2N/m
Number 2..
NOT A CLUE..
PLEASE HELP
40K
15K
