How Does Firing a Photon Torpedo Affect the Speed of a Star-Wars Satellite?
  • Thread starter Thread starter Delzac
    Photon
The problem involves a star-wars laser satellite with a mass of 5000 kg orbiting Earth at a speed of 10.0 km/s, which launches a photon torpedo containing a large number of photons. The question seeks to determine the speed of the satellite after the launch, invoking concepts from momentum and energy conservation.
  • Participants discuss the conservation of momentum and energy in the context of photon momentum. There are attempts to relate the number of photons to momentum and energy equations, with some questioning the relevance of certain equations like K_m_a_x = hf - \varphi.
Some participants have made calculations regarding the momentum of the photons and the resulting speed of the satellite. There is a mix of confirmations and suggestions for rounding the final answer. The discussion reflects ongoing exploration of the problem without a clear consensus on the final result.
Participants note potential confusion regarding the use of certain equations and constants, such as Planck's constant, and the implications of the photon count on momentum calculations. There is also mention of rounding conventions for the final speed result.
Delzac
A star-wars laser satellite, whose mass is 5000 kg, is orbiting Earth at a speed of 10.0 km/s. It launches a photon torpedo at an enemy missile which is directly in front of it. The photon torpedo contains [tex]10^3^3[/tex] photons, each having a wavelength of 200nm. What is the speed of the weapons satellite just after the launch?
Conservation Of Momentum(?)(COM)
[tex]K_m_a_x = hf - \varphi[/tex]
[tex]KE = \gamma mc^2 - mc^2[/tex]
[tex]p = E/c[/tex]
[tex]v = f\lambda[/tex]
Since we have [tex]\lambda = 200nm[/tex] we can then obtain f = 1.5*10^15 Hz.
However, from here on, i am lost. How do we use the number of photons and equate it into [tex]p = E/c[/tex] and finally COM. And then there is also a problem of E which i am unable to find since i don't have h, [tex]K_m_a_x = hf - \varphi[/tex].
Any help will be appreciated. Thanks
This feels like the typical momentum problem involving light, but using sci-fi scale numbers. In these cases, there are a few things to take into consideration:
-conservation of momentum
-conservation of energy
As for the relevant equations, there may have been some confusion on what [tex]K_m_a_x = hf - \varphi[/tex], the photoelectric work function, is used for.
There is also another equation that can be used to find the energy of the photon, not involving [tex]p[/tex]. And h is Plank's constant. Take another look at the possibilities. =)
Well i have calculated i out here's what i have obtain :
[tex]p = \frac{h}{\lambda} * 10^3^3[/tex] Since no. of photon is [tex]10^3^3[/tex]
Then using Conservation of momentum, i get :
[tex]mv = p_p_h_o_t_o_n[/tex]
Which works v out to about 662.6 m/s
The speed of satellite is therefore 10,000 - 662.6 = 9337.4 m/s
Can anyone confirm my result?
What you do seems correct, but the answer should be to 2 sf, so
\delta v=660 and v_sat=9,300.
Thanks for the help
