How to change the melting point of a metal?
The melting point of metals can be altered through the process of alloying, where metals are combined with non-metals or other metals. For instance, combining iron (melting point 1535 °C) with sulfur (melting point 115.36 °C) results in iron disulfide (FeS2), which has a melting point of 1,177-1,188 °C. Similarly, lead (melting point 327.46 °C) and sulfur yield lead sulfide (PbS) with a melting point of 1,116.85 °C. The transformation from sulfide (S) to disulfide (S2) involves changes in chemical bonding, which significantly affects the properties of the resulting compounds.
  • Understanding of alloying processes in metallurgy
  • Knowledge of chemical bonding and compound formation
  • Familiarity with phase diagrams of metals
  • Basic principles of thermodynamics related to melting points
  • Research the effects of alloying elements on the melting points of metals
  • Study the phase diagrams of iron-sulfur and lead-sulfur systems
  • Learn about the thermophysical properties of metal sulfides
  • Explore the chemical processes involved in the formation of metal disulfides
Metallurgists, materials scientists, and chemical engineers interested in modifying the melting points and properties of metals through alloying and compound formation.
Jacquesl
Like example:
Iron melting point: 1535 °C
Sulfur melting point: 115.36 °C
If you combine Iron and Sulfur in a airtight container and light a monster fire under it, you get a sort of a pyrite (iron disulfide (FeS2)– Melting point 1,177-1,188 °C
Lead melting point: 327.46 °C,
If you do the same procedure with lead and sulfur and get some very strange black stuff called Lead sulfide (PbS) melting point 1116.85 °C
Can some please tell me then does something change from sulfide (S ) to disulfide (S2 ) and how can that me done?
The metal Fe is in a different form than a chemical compound (FeS or FeS2), and the bonds between Fe and S are very different than the metal bonds.
Metals are alloyed with other metals in order to change melting point as well as other thermophysical and/or mechanical properties.
  • · Replies 16 ·
10K
