Parametric Curves: Tangent Lines
The discussion revolves around finding equations of tangent lines to the parametric curve defined by x=3t^2+1 and y=2t^3+1, specifically those that pass through the point (4,3). Participants are exploring the conditions under which these tangents can be determined.
  • Participants discuss deriving the tangent line equations at a general value of t and applying the condition that the tangent must pass through the point (4,3). There is mention of obtaining cubic equations from this condition, with one participant noting that t=1 is a known solution.
The conversation indicates that some participants have made progress in finding the second equation of the tangent line, while others express uncertainty and seek clarification on the results. There is an acknowledgment of multiple cubic equations arising from the problem.
There is a noted challenge in determining the appropriate t value for the tangent line below the x-axis, which adds complexity to the problem. The discussion reflects varying levels of understanding and progress among participants.
chefstef00
Find equations of the tangents to the curve x=3t^2+1, y=2t^3+1 that pass through the point (4,3).
I was able to find the equation y=x-1 as a tangent line through the point (4,3) for the part of the curve above the x-axis since (4,3) is on the curve.
However, I do not know how to find the equation of the tangent for the part of the curve below the x-axis since I do not know what point on the curve the tangent passes through and therefore do not know the t value.
Any help is appreciated, thanks
Write down the equation for the tangent line to the curve at general value of t. Now put in the condition (4,3) is on the line. You should get a couple of cubic equations. You already know t=1 is a solution. Is there another?
Well, you get a cubic equation. Knowing that t= 1 is a solution makes it easy to solve. Dick's suggestion is right on the money.
Duh, right. Make that 'one' cubic.
thanks a lot for the help, i was able to find the second equation, thanks
So what *is* that second equation? I'm stuck!
