Light Speed Debate: Is It Possible to Travel Faster?
The discussion centers on the concept of traveling faster than light and the implications of relativistic physics. Participants clarify that while two objects moving away from each other at light speed may seem to exceed light speed, the correct relativistic formula for adding velocities, derived from Lorentz transformations, ensures that their relative speed remains at or below the speed of light (c). The formula used is v = (v1 + v2) / (1 + (v1v2/c²)), which confirms that even at light speed, the relative speed does not exceed c. Misinterpretations of speed addition in relativity are addressed, emphasizing the importance of proper calculations.
  • Understanding of special relativity principles
  • Familiarity with Lorentz transformations
  • Basic knowledge of velocity addition in physics
  • Concept of the speed of light (c) as a universal constant
  • Study the derivation and applications of Lorentz transformations
  • Explore the implications of special relativity on high-speed travel
  • Learn about the experimental confirmations of relativistic physics
  • Investigate the concept of relativistic velocity addition in detail
Physicists, students of physics, and anyone interested in the principles of special relativity and the limitations of speed in the universe.
MentalManager
Like we have learned in school, the ultimate speed is a light speed. Do you believe that? We may be wrong. Let's take an example. There are two objects. They start in the same place and they start moving away from each other. They are traveling in a speed of a light. But isn't the speed they are moving away from each other two times light speed.
v1 C v2
<---O-----*-----O--->
v1 is light of speed and v2 is light of speed. C is where they started. v1+v2 is two times light speed. It seems to me that the distant is growing two times LS. It means that its bigger than light speed.
In relativity the formula for adding speeds is not the usual one. When you use that formula, derived from the Lorentz transformations, you never get the sum of speeds bigger than c.
The justification for the Lorentz transformations is hundreds of thousands of confirming experiments every day.
Or, just possibly, YOU may be wrong. In this particular case, you simply did the arithmetic wrong.
If object A is moving away from point B at speed v1 and object C is moving away from point B with speed v2 in exactly the opposite direction, then the speed of A relative to B is given by
[tex]\frac{v_1+v_2}{1+\frac{v_1v_2}{c^2}}[/tex].
It is easy to see that if v1and v2 are both less than c, then so is this value. In your specifice example, where v1 and v2 are both equal to c (the speed of each relative to B is c) then the speed of each relative to the other is [tex]\frac{2c}{1+ \frac{c^2}{c^2}}= \frac{2c}{2}= c[/tex].
The only objection I have with SelfAdjoint's response is the phrase "In relativity the formula for adding speeds is not the usual one.". It is not the approximation that we commonly use for adding very very low speeds!
  • · Replies 24 ·
  • · Replies 93 ·
  • · Replies 236 ·
18K
  • · Replies 26 ·
  • · Replies 42 ·
