Is Acceleration Affected by Direction and Speed Changes?
The discussion revolves around the effects of direction and speed changes on acceleration, particularly in the context of projectile motion and vehicle acceleration. Participants explore concepts related to gravitational acceleration and the calculations involved in determining time for speed changes.
  • Participants question the nature of acceleration at the peak of a projectile's flight and whether it differs from gravitational acceleration.
  • There is a discussion about whether two balls thrown from the same height, one upwards and one downwards, will have the same speed upon reaching the ground.
  • One participant shares a calculation regarding the time required for a car to accelerate from 60 km/h to 90 km/h, prompting others to inquire about the calculation process.
  • Questions arise regarding the forces acting on a ball in flight and the implications for its acceleration.
The discussion is active, with participants providing insights and questioning each other's reasoning. Some guidance is offered regarding the calculation of time and the importance of unit consistency, but no consensus has been reached on the conceptual questions about acceleration.
Participants are navigating potential misunderstandings regarding the effects of gravity and the necessary unit conversions in their calculations. There is an emphasis on clarifying assumptions about forces acting on objects in motion.
future_vet
Here's my last string of questions... for the week at least! :) Thank you all so much for your help.
If we throw a ball up, is its acceleration just before it reaches its highest point slightly higher than g? This would make sense to me, because if it was at g or lower, it would be ready to fall back down, or would be falling down...
If a ball is thrown up and another is thrown down, when they reach the ground, do they both have the same speed? Also, this would make sense to me, because they are both exposed to gravity.
A car traveling at 60 km/h accelerates at 2.0 m/s^2. How much time is required for the car to reach a speed of 90 km/h?
I calculated 15 seconds for that... It makes sense to me, but we never know...
Thanks!
I wouldn't agree with this. Neglecting air resistance, what forces are acting on the ball when it is in flight? Thus, what is the acceleration of the ball?
If they're thrown from the same point then, yes.
How did you calculate it? I can't check you're right if I can't see what you've done! :smile:
The forces acting on the ball in flight would be gravity?
The acceleration of the ball would be 0?
Correct, and the graviational force is equal at all points during the ball's flight.
Where did this conclusion come from? (Huge hint: what is the acceleration due to gravity?)
Ah oops, here it is:
2.0 m/s^2 = (90 000 - 60 000 m/h)/t
t= 30 000/2
And... I can't figure out how I got my answer then... Maybe I forgot about the km vs meters...
Your units here are incorrect. Your conversion to metres was correct, but on the left you have seconds, and on the right you have hours. You need to convert the expressions on the right to m/s before you can calculate t.
  • · Replies 16 ·
