I really don't get the substitution rule
  • Thread starter Thread starter tony873004
    Substitution
The discussion revolves around the substitution rule in calculus, specifically in the context of integrating functions involving trigonometric expressions. The original poster expresses confusion regarding the application of the substitution rule and the appearance of a constant factor in the final answer.
  • Participants explore the correct application of the substitution rule, questioning the relationship between variables and the need for adjusting differential elements during integration. There is a focus on understanding how to properly substitute and manipulate differentials.
Some participants provide clarifications regarding the integration process and the role of differentials, while others share their own experiences with similar problems. The discussion reflects a mix of understanding and lingering questions about notation and integration techniques.
Participants mention frustrations with notation, particularly Leibnitz notation, and express a desire for more thorough explanations of its use in calculus courses. There is also an acknowledgment of varying levels of difficulty in problems based on prior knowledge.
tony873004
I really don't get the substitution rule. This is supposed to be the easiest problem in the homework set: u=3x
[tex]\int {\cos \,3x\,\,dx\,\, = \,\,\int {\cos \,u\,\, = \,\,\sin \,u + C\,\, = \,\,\sin 3x + C} }[/tex]
But the right answer is 1/3 sin(3x). Where did the 1/3 come from?
Look at your second integral in here:
[tex]\int {\cos \,3x\,\,dx\,\, = \,\,\int {\cos \,u\,\,dx?\,\, = \,\,\sin \,u + C\,\, = \,\,\sin 3x + C} }[/tex]
with respect to what variable? x?
or, did you mean to have a du in there?
If you meant for a du to be there, what makes you think that du can be substituted for dx? You wrote u=3x. if I take the derivative, with respect to x, I get du/dx = 3. Multiplying both sides by dx (thanks, Leibnitz for that notation), I get du = 3 dx. And from that, dx will be equal to 1/3 du
Actually, I think a "harder" integral will make this easier to see:
[tex]\int {\sec x \sec x \tan xdx[/tex]
Let u = secx
du/dx = secxtanx
du = secxtanxdx
Now, when you substitute, u will take care of the first secx.
But, du will take care of the rest of it: secxtanxdx
I think I did it right, but I still have a question.
[tex]u = 3x,\,\,\,\,\frac{{du}}{{dx}} = \left( {3x} \right)^\prime = 3,\,\,\,\,dx = \frac{{du}}{\begin{array}{l}<br /> 3 \\ <br /> \\ <br /> \end{array}},\,\,\,\,\int {\cos \,3x\,\,dx\,\,} = \,\,\int {\cos \,u\,\,\frac{{du}}{3} = \frac{{\sin u}}{3}} = \frac{{\sin 3x}}{3}[/tex]
So when I integrate, the du simply disappears?
I hate Leibnitz notation. I do not think it is intuitive. I wish in Calc 1 they would have spent a lecture on Leibnitz notation. Rather, they just started using it without describing it.
Yes, the du disappears with the integral sign (as would dx, dy, etc). Kind of like: 4 + 3 = 7, we don't leave the + there.
[tex]\int {\cos \,u\,\,\frac{{du}}{3}[/tex]
At this point you should factor out the constant, 1/3, from the integral:
[tex]\frac{1}{3} \int {\cos \,u\,\,du[/tex]
mattmns said:
...Kind of like: 4 + 3 = 7, we don't leave the + there.
:smile: Thanks to you, I will never forget that.
Thanks, everyone. :rolleyes: This was so confusing to me until I asked here. I just plowed through the next 10 problems with ease. But I'm stuck on the 11th, so I'm giving up for the night.
Man, that was an easy problem. Think forward of the answer. I guess light years will come up for your mind to catch up.
It's only easy if you know the answer! When learning, any problem can be difficult if you can't see what to do!
  • · Replies 25 ·
