How Do You Determine a Particle's Velocity as a Function of Position?
  • Thread starter Thread starter s4orce
    Dynamics Particle
The problem involves determining a particle's velocity as a function of its position, given a specific acceleration formula related to position. The acceleration is defined as a = (4s^2) m/s², with initial conditions provided for velocity and position.
  • Participants discuss the relationship between acceleration, velocity, and position, with attempts to integrate the acceleration function. Questions arise regarding the interpretation of differential equations and the correct approach to solving them.
The discussion is ongoing, with participants exploring different methods to solve the differential equation. Some guidance has been offered regarding the nature of the problem and the importance of deriving an expression rather than seeking a numerical answer. There is a recognition of the need for further clarification on solving the differential equation.
Participants note that the question is not asking for a numerical answer but rather for an expression for velocity. There is an emphasis on the importance of engaging with the problem rather than seeking direct solutions.
s4orce
1. A particle is moving along a straight line such that its acceleration is defined as a=(4s^2)m/s^2, where s is in meters. If v=-100m/s when s=10m and t=0, determine the particles velocity as a function of position.
2. V=ds/dt a=dv/dt
3. V=ds/dt a=dv/dt 1/dt=ads*vdv
Integral 100 to s 4s^2ds=Integral -100 to v vdv
Integral 4s^2=4s^3/3
What do I do now, the answer is 16.89 ft. but I don't know how-to get that from the derivation. Need Help Thanks!
What've you done here: 1/dt=ads*vdv?
Your first equation a=4s2 is a differential equation: namely [tex]\frac{d^2s}{dt^2}-4s^2=0[/tex]. Do you know how to solve such an equation?
help me solve this please
need help i don't know what to do
Cristo gave you the equation, so solve the diff eq. Also the answer to the problem that you posted 16.89 ft, is not right. The question isn't asking for a numerical answer.
Another way is take the equations you have V=ds/dt a=dv/dt and eliminate dt and just integrate and do the algebra.
can you post how you did it please
if you got 15, for the answer that's not it also
s4orce, the question is not looking for a numerical answer; it is looking for an expression for velocity. The way I would do it, would be to solve the ODE I gave you in post 2, and then differentiate the answer wrt time.
Do you know how to solve such a differential equation?
Please note that we will not do your homework for you here; it won't help you learn the subject! What we will be happy to do is to help guide you to answer, if you put some work in. Check this link for the PF rules on homework help: https://www.physicsforums.com/showthread.php?t=5374
