Thread Closed
Firing a projectile, max height + flight time
Share Thread Thread Tools
Feb2-07, 03:00 PM   #1
A projectile is fired with an initial speed of 65.2 m/s at an anmgle of 34.4 degrees above the horizontal on a long flat firing range.
Determine the max heigh reached by the prkectile, the total time in the air and the total horizontal distance covered and the velocity of the projectile 1.50 seconds after firing.
2. Relevant equations and 3. The attempt at a solution
I am going to check the first parts now, and then continue once I am sure I am going in the right direction.
Vxo = vocos 34.5 = 65.2/0.824 = 79.1 m/s
Vyo = vosin34.5 = 65.2/0.566=115 m/s
t=vyo/g=11.7 seconds.
y=Vyot - 1/2gt^2= 675 meters maximum height.
And
y=yo + vyot - 1/2 gt^2
0 = 0 + 115t - 1/2 x 9.80 x t^2
t = 0 at initial point
t= 2 (115)/9.80 = 23.5 seonds.
Thanks!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Feb2-07, 03:13 PM   #2
Actually here's the third part
Range:
x = 0. ax=0, vxo= 79.1 m/s and 11.7x2 = 23.4 which is the total time for the whole "trip".
x= 79.1 x 23.4 = 1850.94 meters
For the velocity after 1.50 seconds, I have no idea how to proceed... Some help would be greatly appreciated. Thanks!
Feb3-07, 08:47 AM   #3
Do I use the same equation as in the previous part:
but replace 23.4 by 1.50 seconds
=> 79.1 x 1.5 = 118.7 meters ?
How about the significant figures throughout the exercise?
Thanks!
Feb3-07, 09:00 AM   #4
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
Quote by future_vet View Post
?? You say Vxo= vocos 34.5 but then you DIVIDE by cos 34.5? Same for Vyo. Surely the x and y components of speed can't be greater than the speed itself!
And
Thanks!
Your values for vxo and vyo are wrong. Recalculate them- multiply by the trig functions- and recalculate the rest.
Range:
Again, your value for vxo is wrong. Recalculate.
Thanks!
"x" is not the velocity, it's horizomtal distance. The velocity is the <vx, vy> vector. Since, as you said before, there is no horizontal acceleration, vx is just vxo. vy is, of course, vyo- gt.
Feb3-07, 09:01 AM   #5
Mentor
Check these components: Vx0=V0*cos34.5; here you've divided!
(plus you've put 34.4 in the first line of the question!)
Feb3-07, 09:41 AM   #6
!!! How brainless.
Well, here is the correction:
Same but multiplying instead gives us 5.15 m/s and 36.9 m/s.
t= 3.77 seconds.
Then for the distance following y=Vyot - 1/2gt^2= 69.5 meters maximum height.
Feb3-07, 09:44 AM   #7
Then we have
0 = 0 + 36.9t - 1/2 x 9.80 x t^2
t= 2 (36.9)/9.80 = 7.5 seconds.
Feb3-07, 09:47 AM   #8
And finally for the range:
The time was 3.77 => 3.77 x 2 = 7.54 seconds for the whole trip
x= 5.15 x 7.54 = 38.8 meters
Feb3-07, 11:46 AM   #9
Mentor
!!! How brainless.
t= 3.77 seconds.
Check the x component of the initial velocity again. Other than that, I've not checked your arithmetic, but your method is correct.
Then we have
Correct
x component of initial velocity is incorrect (as above)
For the last question, do I replace 7.54 by 1.5 seconds to find the distance after 1.5 seconds?
Yes, but don't you want the velocity after 1.5 seconds?
Feb3-07, 11:48 AM   #10
Quote by cristo View Post
Oops... It is 34.5 degrees... =/
Feb3-07, 01:31 PM   #11
Mentor
OK, I thought as much, and that that was a typo. Did you see my above post re a mistake in the x component of the initial velocity?
Feb3-07, 04:18 PM   #12
Yes, thank you! It did look small. I can't believe I am making so many mistakes...
Feb3-07, 04:23 PM   #13
Actually, yes I need the velocity not the distance.
Do I use:
vyo- gt = the velocity
=> = 36.9m/s - 9.80 m/s^2 x 1.50 seconds = 14.85 m/s ?
I think I spent too much time on this exercise, nothing is making sense anymore and I am mixing up my numbers...
Feb3-07, 04:45 PM   #14
Mentor
Do I use:
That gives you the y component of the velocity at the time t=1.5. Then calculate the x component of the velocity at this point.
To calculate the velocity at this point you need to find (a) the speed (i.e. magnitude of the velocity) at this point, and (b) the angle the velocity makes to the horizontal.
So, you can write the velocity v at this point to be v=(vcosθ, vsinθ), and you need to solve equations for v and θ
Thread Closed
Thread Tools
Similar Threads for: Firing a projectile, max height + flight time
Thread Forum Replies
Projectile Flight (LAunch) Introductory Physics Homework 13
Firing Solution - Projectile Motion Classical Physics 2
Projectile Motion, A study of height and time Introductory Physics Homework 1
Projectile Motion: 3D Firing Solution Vector General Physics 5
fortran prog - flight traj of projectile Introductory Physics Homework 6
