How Is Work Calculated When Removing a Dielectric from a Charged Capacitor?
  • Thread starter Thread starter clarr1
    Dielectric
The work required to remove a dielectric from a charged parallel-plate capacitor connected to a 100 V battery can be calculated by analyzing the changes in potential energy. Initially, the potential energy with the dielectric (K=3.4) is given by the formula 0.5(3.4((8.85E-12*A)/d))*(100^2). Once the dielectric is removed, the capacitance changes to C=(8.85E-12)A/d, and the potential energy without the dielectric is calculated as 0.5(C)(V^2). The charge that flows back into the battery upon removal of the dielectric does not change the battery voltage, as the battery maintains a constant voltage output. The difference in potential energy before and after the dielectric removal will yield the work done.
  • Understanding of parallel-plate capacitors
  • Knowledge of dielectric materials and their effects on capacitance
  • Familiarity with potential energy equations in capacitor systems
  • Basic principles of electric charge and voltage in circuits
  • Study the effects of dielectrics on capacitance in capacitors
  • Learn about energy storage in capacitors and the role of potential energy
  • Explore the relationship between charge, voltage, and capacitance in circuits
  • Investigate the implications of connecting capacitors to batteries during charge and discharge cycles
Physics students, electrical engineers, and anyone studying capacitor behavior in electric circuits will benefit from this discussion.
clarr1
A parallel-plate capacitor filled with dielectric K=3.4 is connected to a 100 V battery. After charging, the dielectric is removed and the battery remains connected. What would be the work required to remove the dielectric.I've done a problem similar to the one above, however, the battery was disconnected. Also, this problem doesn't give the area (A) or distance (d) of the capacitor, which would seem essential. But, I haven't gotten the problem correct after 20 or so attempts so what would I know?
What I do know is that the potential energy with the dielectric is:
and without the dielectric, the capacitance is: C=(8.85E-12)A/d
and the potential energy here is: .5(C)(V^2)=U
however, I know that when the dielectric is removed, charge flows back into the battery. Would this charge be the difference in charge on the plates before and after the dielectric is removed. And will this charge change the voltage of the battery. So, would i have to find the change in charge and add it to the constant charge of the battery to find the new voltage of the battery after the dielectric is removed? and would this charge go into the potential energy equation for after the dielectric is removed? and then would i subtract the two?Thanks
So I know how to get the potential energy before the dielectric is removed. But when it is removed, charge goes from the plates back to the battery, making the charge with and without the dielectric equal. So really, my main question is this: does the charge traveling back into the battery change the voltage output of the battery which would be included in the second potential energy equation?
  • · Replies 17 ·
