How Much Force to Apply on a Lawnmower Handle at an Angle for Desired Velocity?
  • Thread starter Thread starter danago
    Angle Force
The problem involves calculating the force required to push a lawnmower at a specific velocity, considering the angle of the handle and the mass of the lawnmower. The context is rooted in dynamics and force analysis.
  • Exploratory, Assumption checking
  • The original poster attempts to calculate the necessary force based on the desired acceleration and the angle of the handle. Some participants question the completeness of the problem statement, particularly regarding the absence of friction.
The discussion is ongoing, with participants exploring the implications of the problem setup. There is a recognition of a potential discrepancy between the original poster's calculations and the answer provided in the book, leading to further inquiry about the problem's assumptions.
The problem explicitly states there is no friction, which some participants find noteworthy in evaluating the correctness of the provided answer.
danago
A lawnmower weighing 20kg has a handle attached at 35 degrees to the horizontal. If a man wishes to push the lawnmower, so that after 2.5s, its velcoity is 2 m/s, what force should he apply along the handle.
[tex] \sum {\overrightarrow F } = m\overrightarrow a [/tex]
ok, since after 2.5 seconds, it requires a velocity of 2 m/s, i found the acceleration of the mower to be 0.8 m/s/s. Since it has a mass of 20kg, the net force applied must then be:
[tex] \sum {\overrightarrow F } = 20 \times 0.8 = 16N[/tex]
So the horizontal component of the force he applies must be 16N in the direction of acceleration.
The horizontal component of the force (F) he applies down the handle will be [tex]F cos 35[/tex]. So solving for F:
[tex]Fcos35=16[/tex]
Gives F=19.5N.
According to the answer book, the answer is 120N. Where have i gone wrong?
Thanks,
Dan.
If the question is quoted correctly, then I would agree with your answer. Does the text not mention any other factors, such as friction?
Nope, no friction at all. What I've said is pretty much quoted word for word from the book.
Thanks for the reply.
yeah the book is def. wrong
ok that's good to hear :) Thanks for the help
  • · Replies 56 ·
