True or False on kinetic energy
The discussion revolves around determining the truth of various statements related to kinetic energy and work, including concepts of motion, potential energy, and vector relationships.
  • Participants are evaluating the truth of multiple statements regarding kinetic energy and work, with some expressing uncertainty about their reasoning and others questioning specific statements.
There is an active exploration of the statements, with participants providing insights and corrections. Some statements have been identified as true or false, but there remains a lack of consensus on the overall correctness of the original selections.
Participants are navigating the implications of definitions and conditions, such as the relationship between work and the speed of raising an object, and the special case regarding the work done on springs when stretched by zero distance.
PhysicsPhun
The question asks for which of these statements is true.
a) The Kinetic Energy of an object depends on the direction of the motion involved.
b)The kinetic energy of any object is either positive or Zero.
c) If the scalar product (also called the dot product) of two nonzero vectors is zero, then the vectors must be perpendicular to each other.
D) Spring A and B are identical except that A is stiffer than B; that is Ka > Kb. More work must be expended on spring A if both springs are stretched by the same amount.
E) If the Earth revolves around the sun in a perfectly circular orbit, then the sun does not do any work on the earth.
F) The work done to raise a box onto a platform depends on how fast it is raised.
What i thought was that BCD and F were all true.. but apparently that's incorrect.
Does anyone have any ideas?
F is false. It does not matter how fast you raise the box, provided it is at rest when you are done. The work done upon it is mgh, m=mass, g=gravitational acceleration, h=height. This is the change in the box's potential energy. While it is true that you also added kinetic energy while the box was being raised, while it is at rest on a shelf, it has 0 kinetic energy.
Njorl
BCD is not the correct answer either.. Did i mess up somewhere else?
E is true as well. The force is perpendicular to the displacement, so no work is done.
Thanks to both of you. Much appreciated.
I know answer B is also true.
BCDE are true.
AF are false.
D has a special case. If "the same amount" is zero, then the same work is done on both springs. It is a false statement for that special case.
Njorl
  • · Replies 33 ·
  • · Replies 54 ·
12K
9K
