| Thread Closed |
CIRCUIT ANALYSIS: 8 Resistors, 1 IVS, 1 Differential Op-Amp - Find Vo |
Share Thread | Thread Tools |
| Feb5-07, 12:29 AM | #1 |
The circuit below is a differential amplifier driven by a bridge, find [itex]V_0[/itex]. ![]() 2. Relevant equations KCL, v = i R, Ideal Op-Amp relationships 3. The attempt at a solution I added 4 voltage markers. ![]() By the Ideal Op-Amp relationships, we know that there is 0 current at both input terminals of the Op-Amp. KCL at [itex]V_2[/itex]) [tex]\frac{0.005\,-\,V_2}{40000}\,=\,\frac{V_2}{60000}\,+\,\frac{V_2\,-\,V_4}{20000}[/tex] [tex]18\,V_2\,-\,12\,V_4\,=\,0.003[/tex] < ------ Equation 1 KCL at [itex]V_4[/itex]) [tex]\frac{V_2\,-\,V_4}{20000}\,=\,\frac{V_4}{80000}[/tex] [tex]4\,V_2\,-\,5\,V_4\,=\,0[/tex] <----- Equation 2 Now, using equations 1 and 2, I get [itex]V_2\,=\,0.003571\,V[/itex] and [itex]V_4\,=\,0.002857\,V[/itex]. Does that seem right? By the relationships of an ideal Op-Amp, [itex]V_3\,=\,V_4[/itex], so [itex]V_3\,=\,0.002857\,V[/itex]. KCL at [itex]V_1[/itex]) [tex]\frac{0.005\,-\,V_1}{10000}\,=\,\frac{V_1}{30000}\,+\,\frac{V_1\,-\,V_3}{20000}[/tex] [tex]11\,V_1\,-\,3\,V_3\,=\,0.03[/tex] <----- Equation 3 KCL at [itex]V_3[/itex]) [tex]\frac{V-1\,-\,V_3}{20000}\,=\,\frac{V_3\,-\,V_0}{80000}[/tex] [tex]4\,V_1\,-\,3\,V_3\,+\,V_0\,=\,0[/tex] <----- Equation 4 Using equations 3 and 4, I get [itex]V_0\,=\,0.004363\,V[/itex]. [tex]V_0\,=\,4.363\,mV[/tex] <------ Is that right? |
| Feb5-07, 08:42 AM | #2 |
Bump - Bump:)
| Feb5-07, 11:09 AM | #3 |
Looks good. Quick question though, why don't you use linear algebra instead of messy substitutions?
| Thread Closed |
| Thread Tools | |
Similar Threads for: CIRCUIT ANALYSIS: 8 Resistors, 1 IVS, 1 Differential Op-Amp - Find Vo
| CIRCUIT ANALYSIS: Non-Inverting Ideal OpAmp, 2 resistors, 1 IVS - Find Thevenin Equiv | Introductory Physics Homework | 4 | ||
| CIRCUIT ANALYSIS: Non-Ideal OpAmp with 2 resistors - Find Thevenin Equivalent | Introductory Physics Homework | 1 | ||
| CIRCUIT ANALYSIS: 3 Resistors, 3 Voltage Src, 1 Current Src - Find v1, v2, v3 | Engineering, Comp Sci, & Technology Homework | 3 | ||
| CIRCUIT ANALYSIS: 7 resistors, 2 Indep. Volt Source, V.C.C.S, V.C.V.S. - find I | Engineering, Comp Sci, & Technology Homework | 24 | ||
| CIRCUIT ANALYSIS: 2 resistors, Indep. Current Source, V.C.C.S - find v0 | Engineering, Comp Sci, & Technology Homework | 37 | ||
