Softening 8mm Allen Key - Temperature & Annealing Process
  • Thread starter Thread starter Shedfull
The discussion revolves around the temperature and annealing process required to soften an 8mm allen key for machining and threading. Participants explore the necessary heating techniques and considerations for working with the material.
  • Exploratory, Technical explanation, Debate/contested, Experimental/applied
  • One participant inquires about the specific temperature needed to soften an 8mm allen key, suggesting the use of an electric muffle furnace that reaches 1200°C.
  • Another participant mentions a transformation temperature of around 920°C and notes that annealing will affect the entire wrench.
  • A participant proposes using a spark test to determine the carbon content of the allen key, which could inform the appropriate temperature for annealing.
  • There is a suggestion that a small part like an allen wrench would be completely annealed in about an hour.
Participants generally agree on the approach to annealing the allen key, but there are varying opinions on the specifics of temperature and soaking time, indicating some uncertainty and lack of consensus.
Participants reference specific temperatures and processes without confirming their accuracy, and there is mention of the need to consider carbon content, which may influence the annealing process.
Individuals interested in machining, materials science, or those looking to understand the annealing process for small metal parts may find this discussion relevant.
Shedfull
Hi, would anyone know the temperature required to soften an 8mm allen key?
I want to machine the end and thread it, from what I can gather, I need to heat it, then let it slowly cool.
I have access to an electric muffle furnace, goes to 1200°C
I know I could use hex stock, but the allen key is just the right size.:smile:
Lee.
I'd have to pull out my tool steels reference at work tomorrow morning. You would most likely be fine getting above the transformation temperature (920C IIRC) and furnace cooling after that. The only drawback to this is that the entire wrench is going to be annealed.
Are you stuck on doing the machining yourself? We thread hardened shafts and tools all the time. It's not difficult if you have the right tools. Do you know if there is a thread grinding shop anywhere near you? They could do it and probably would not cost you too terribly much. Just a thought.
stuck on the machining
Hi, I'm machining the parts myself, with no budget, but lots of ideas &
theories.
I did a bit of googling and came up with a rough solution.
here goes,
If I do a spark test on the allen key, I should get an idea of the carbon content.
Knowing the carbon content gives me a starting point for the temp.
All I have to do then is find/work out the time the part should be soaked for
(1 hr/inch?)
Am I on the right track? if so this would be good for future ref.
Lee.
Yes. You're on the right track. Really, a small part like an allen wrench would be completely annealed in an hour. As far as the temp, I'll have to look that one up.
17K
10K
13K
