Register to reply
Finding Recoil Velocity
by grewas8
Tags: recoil, velocity
Share this thread:
grewas8
#1
Feb6-07, 11:56 AM
P: 16
Oliver has a mass of 59.1 kg and can throw a 558.0 g rock with a speed of 19.8 m/s. What would Oliver's recoil speed be if he were on an icy surface?
2. Relevant equations
Momentum is conserved in an isolated system (when Fnet=0 or no external forces are acting on the system)
p=mv
mass(object 1)*initial velocity (object 1) + mass(object2)*initial velocity (object 2)= Mass (object 1)*final velocity (object 1) + mass (object 2)*final velocity (object 2)
3. The attempt at a solution
m (oliver)= 59.1 kg, m(rock)= 0.588 kg, initial velocity = 19.8 m/s
p(oliver+ rock)= mv
p= (59.1+0.588)(19.8) =1181.8 kg m/s (seems quite too large--> unreasonable?)
on ice (frictionless i assume) no net external forces so Fnet=0
i don't understand what recoil velocity means? Is it the rebound velocity? would be equal and opposite?
***Any help would be appreciated ****
Phys.Org News Partner Science news on Phys.org
Scientists develop 'electronic nose' for rapid detection of C. diff infection
Why plants in the office make us more productive
Tesla Motors dealing as states play factory poker
Doc Al
#2
Feb6-07, 12:10 PM
Mentor
Doc Al's Avatar
P: 41,476
Realize that Oliver and his rock are originally at rest on the ice. So what is the original momentum of the sytem?
Also, "recoil velocity" is the speed that Oliver will move back with (recoil) after he throws that rock. (If he throws the rock East, he will recoil to the West.)
neutrino
#3
Feb6-07, 12:13 PM
P: 2,046
p(oliver+ rock)= mv
Where is it mentioned that Oliver is travelling at 19.8m/s?
Recoil velocity refers to velocity with which Oliver would be moving AFTER he throws the ball.
Take a look at the equation you posted and just substitute the values.
grewas8
#4
Feb6-07, 01:02 PM
P: 16
Would the orginal momentum be zero
so would i use 0 as the momentum and find velocity from there?
i am so confused
also it says that if oliver throws the rock he would throw it at 19.8 m/s
so is that the velocity at the instant he throws it?
i seem to be more confused..?
Doc Al
#5
Feb6-07, 01:20 PM
Mentor
Doc Al's Avatar
P: 41,476
Quote Quote by grewas8 View Post
Yes, the initial momentum is zero. Before he throws the rock, nothing is moving.
Yes, assume that when he's done throwing the rock, that that is the rock's final speed.
neutrino
#6
Feb6-07, 01:22 PM
P: 2,046
Yes
Yes. Since no external force is said act in the horizontal direction, it would continue with the same velocity.
neutrino
#7
Feb6-07, 01:23 PM
P: 2,046
Okay, I'm late by only 2 minutes this time. :D
grewas8
#8
Feb6-07, 04:45 PM
P: 16
Its seems that since that 19.8 m/s is the velocity oliver will continue with, hence that would be the recoil velocity?
But i tried that its not the answer. Ughhh...
I am gonna think about this question later since i should really study for my bio midterm.
Doc Al
#9
Feb6-07, 06:17 PM
Mentor
Doc Al's Avatar
P: 41,476
19.8 m/s is the speed of the rock, not Oliver. You have to apply conservation of momentum to solve for Oliver's recoil speed.
grewas8
#10
Feb6-07, 07:18 PM
P: 16
Quote Quote by Doc Al View Post
Is this wrong?:
(mass of oliver)* (oliver's velocity)= (mass of rock) (velocity of rock)
(59.1)(v)= (0.588) (19.8)
v= 0.588*19.8/59.1
v=0.196?
neutrino
#11
Feb7-07, 02:10 AM
P: 2,046
Is this wrong?:
v= 0.588*19.8/59.1
v=0.196?
Yes. In the sense that you forgot a minus sign.
From the origianl equation:
0 = msvsf + movof (s refers to stone and o to Oliver, f - the final velocity)
Therfore,
vof = -(msvsf)/mo
The minus sign is important because you are solving for velocity, and not just speed. The sign says that Oliver would move in the opposite direction with a speed of 0.197m/s.
jebohanner
#12
Jun15-10, 12:06 AM
P: 2
Can someone please help me solve this problem?
A 60kg teenager on in-line skates intially at rest holds a 0.5kg ball. The teenager throws the ball horizontally at a speed of 12m/s relative to the ground and recoils backwards.
Ignoring friction, what is the recoil speed of the skater?????
Doc Al
#13
Jun15-10, 07:05 AM
Mentor
Doc Al's Avatar
P: 41,476
Quote Quote by jebohanner View Post
Hint: Momentum is conserved. What's the total momentum of the skater + ball system?
jebohanner
#14
Jun15-10, 11:09 PM
P: 2
Can you please show me in steps???? and what formula do I use?????
Doc Al
#15
Jun16-10, 05:14 AM
Mentor
Doc Al's Avatar
P: 41,476
It doesn't work that way. You make an attempt, show what you did and where you are stuck, then we'll jump in and help.
As far as which formula to use: See my hint! And read the thread that you chose to hijack! (It's practically the same problem.)
If you have no idea at all about conservation of momentum, read up in your text.
finklelaceout
#16
Jun3-12, 02:11 PM
P: 1
Use m1*initial velocity1 + m2*initial velocity2= m1*final velocity1+ m2*final velocity2
m1= Oliver
m2= The Rock
Oliver has no initial velocity so initial velocity1 is gone. The rock's finals velocity will be zero, so final velocity2 is gone.
You're left with:
m1+m2*initial velocity2=m1*final velocity1+m2
You should get his recoil velocity from that. If you don't then I'm wrong..and it wouldn't be the first time lol.
(59.1)+(.558)(19.8)=(59.1)*final velocity2+.558
Register to reply
Related Discussions
Find the recoil velocity of the nucleus. Introductory Physics Homework 1
Recoil velocity Introductory Physics Homework 2
Recoil velocity - help! Introductory Physics Homework 2
In order to find the recoil velocity of a spring Introductory Physics Homework 1
Recoil velocity Classical Physics 1
