Is There an Equation for Calculating Energy Output from Gravity?
  • Thread starter Thread starter lanchester
The equation for calculating the energy output of a weight being pulled by gravity is derived from the work-energy principle, expressed as Work = force * distance. The gravitational force is defined by the equation F = GMm/R², where R is the distance from the center of mass. The change in energy when moving a distance dR closer to the center is represented as dW = GMm/R² * dR. Consequently, the power output is calculated using P = dW/dt = GMm/R² * (dR/dt), where (dR/dt) is the radial speed towards the center.
  • Understanding of gravitational force equations
  • Familiarity with the work-energy principle
  • Knowledge of calculus for differentiation
  • Basic physics concepts related to energy and power
  • Study gravitational force calculations using GMm/R²
  • Explore the work-energy theorem in classical mechanics
  • Learn about power calculations in physics
  • Investigate the implications of radial speed in gravitational systems
Physics students, engineers, and anyone interested in understanding gravitational energy dynamics and power calculations in mechanical systems.
lanchester
is there an equation that could be used to determine the energy output of a given weight being pulled by gravity?
Yes, it's the same equation as the work done by any other force:
I think you mean power (energy per unit time) of the weight. Since the gravitational force is:
[tex]F = \frac{GMm}{R^2}[/tex]
where R is the distance of the object from the centre of mass of the large mass (toward which the weight is gravitating), the change in energy by moving a distance dR closer to the centre would be:
[tex]dW = \frac{GMm}{R^2}dR[/tex]
so the power output would be:
[tex]P = dW/dt = \frac{GMm}{R^2}\frac{dR}{dt} = \frac{GMm}{R^2}\dot r[/tex]
where [itex]\dot r[/itex] is the radial speed or the speed toward the centre.
AM
  • · Replies 18 ·
  • · Replies 26 ·
  • · Replies 38 ·
  • · Replies 74 ·
11K
