What forces are involved in an inclined elevator boat lift?
  • Context: Undergrad
  • Thread starter Thread starter qtp
    Boat Lift Mechanics
The discussion focuses on the forces involved in an inclined elevator boat lift, specifically the torque exerted on the inclined arm due to the weight of the boat. The torque remains constant as the boat moves, calculated as the weight of the boat multiplied by the distance from the center of the boat to the inclined arm. Participants question whether additional forces come into play that could increase torque as the boat ascends, particularly concerning the stability of the setup at varying heights. The inclined arm's support on the seawall and its underwater anchoring are also noted as critical factors in the system's stability.
  • Understanding of basic physics concepts, particularly torque and stability.
  • Familiarity with inclined planes and their mechanics.
  • Knowledge of forces acting on structures, including weight distribution.
  • Basic principles of mechanical engineering related to lifting systems.
  • Research the principles of torque in mechanical systems.
  • Study the stability analysis of inclined structures.
  • Explore the mechanics of boat lifts and their design considerations.
  • Learn about the effects of weight distribution on the stability of inclined systems.
Engineers, physics students, and anyone interested in the mechanics of inclined lifting systems will benefit from this discussion.
qtp
Hi,
I have a question regarding the forces involved in an inclined elevator boat lift. Attached is a diagram of the setup. I was wondering what forces are involved. I know that there is a torque that is exerted on the inclined arm equal to the weight of the boat times the distance of the center of the boat from the inclined arm. This torque does not change as the boat moves up and down the lift. However, are there other forces involved that would cause a greater torque on the inclined arm the higher the boat moves up and down the lift? For example, is the setup more likely to tip over when the boat is higher up the lift? Or is the setup just as stable regardless of how high the boat is. Also, the inclined arm is resting on the seawall and is driven down into the ground underwater. Thank you for any light you can shed on this :) attached is the diagram
Preston
I approved the attachment. Is this a homework problem? If so, I can move it to the Physics homework forums.
thank you for approving it. this is not a homework problem. it is just a curiosity thing thank you
  • · Replies 128 ·
12K
  • · Replies 16 ·
