| Thread Closed |
helium balloon |
Share Thread | Thread Tools |
| Mar1-04, 10:21 PM | #1 |
helium balloon
I can't seem to figure this simple helium balloon problem out? I would really appreciate some help? Thanks!
Estimate the volume of a helium-filled balloon at STP if it is to lift a payload of 500 kg. The density of air is 1.29 kg/cubic meter and helium has a density of .178 kg/cubic meter. I think you use a formula like force bouyancy equals density of air times volume times gravity????????? but not quite sure. |
| Mar1-04, 10:46 PM | #2 |
let V : Volume
a= density of air b= density of He we have Code:
V*a=500*103+V*b |
| Mar1-04, 11:09 PM | #3 |
How are you supposed to solve this equation with two unknowns?
| Mar1-04, 11:22 PM | #4 |
helium balloon
only V is unknown
| Mar1-04, 11:45 PM | #5 |
How do you solve
V(1.29)= 500000+V(0.178) and is this really your answer????????? |
| Mar1-04, 11:49 PM | #6 |
(1.29-0.178)V=500 V=450 m3 |
| Mar1-04, 11:54 PM | #7 |
Where does the 500 come from?
| Mar2-04, 12:00 AM | #8 |
isn't it the weight of the payload
| Mar2-04, 12:21 AM | #9 |
Oh Yah! Thanks a Bunch!
| Sep15-04, 12:07 AM | #10 |
The values:
Balloon diameter : 100 feet Balloon weight : 10,000 pounds Payload weight : 6,000 pounds Lifting gas : Helium Air density at ground level : .0625 lbs/cubic foot Temperature is constant At what altitude does the balloon fly? So far I've got: h = alpha [0.862 - (16,000 lbs/ mass of air)] I'm not even sure what the variables are, I was given 47 different formulas to determine the answer to this question, none of which are helping whatsoever. |
| Sep15-04, 12:16 AM | #11 |
| Sep15-04, 12:26 AM | #12 |
Which is:
mass of air (at Height, h) = [mass of payload+mass of balloon+mass of lifting gas] is that the right one? |
| Thread Closed |
| Thread Tools | |
Similar Threads for: helium balloon
| Helium Balloon and spring | Introductory Physics Homework | 8 | ||
| Helium Balloon... | Introductory Physics Homework | 10 | ||
| Helium Balloon | Introductory Physics Homework | 1 | ||
| helium balloon | Engineering, Comp Sci, & Technology Homework | 1 | ||
| Helium Balloon | Introductory Physics Homework | 4 | ||
