Transfer Function of Coupled Diff Eq
The discussion focuses on deriving the transfer function for two coupled harmonic oscillators represented by the equations \(\ddot{x}_{1} = -2kx_{1} + kx_{2} + f(t)\) and \(\ddot{x}_{2} = kx_{1} - kx_{2}\). The Laplace transform is applied to both equations, resulting in \(X_{1} = \frac{ F(p) + k X_{2} }{ p^{2} + 2k }\) and \(X_{2} = \frac{ k X_{1} }{ p^{2} + 2k }\). Substituting \(X_{1}\) into \(X_{2}\) leads to the transfer function \(T(e^{jwt}) = \frac{ z^{-2} + 2kz^{-4} }{ 1 + 4kz^{-2} + 3k^{2}z^{-4} }\). The method is confirmed to be valid for finding the transfer function of coupled differential equations.
  • Understanding of Laplace transforms
  • Familiarity with coupled differential equations
  • Knowledge of harmonic oscillators
  • Basic concepts of transfer functions
  • Study the application of Laplace transforms in control systems
  • Explore the stability analysis of coupled oscillators
  • Learn about the frequency response of transfer functions
  • Investigate the use of MATLAB for simulating coupled differential equations
Students and professionals in engineering, particularly those specializing in control systems, mechanical systems, or applied mathematics, will benefit from this discussion on deriving transfer functions from coupled differential equations.
dimensionless
I have two coupled harmonic oscillators:
[tex]\ddot{x}_{1} = -2kx_{1} + kx_{2} + f(t)[/tex]
[tex]\ddot{x}_{2} = kx_{1} - kx_{2}[/tex]
Mass 1 is at position [tex]x_{1}[/tex] and subject to force [tex]f(t)[/tex].
I take the Laplacian of the first equation and solve for [tex]X_{1}[/tex] to get
[tex]X_{1} = \frac{ F(p) + k X_{2} }{ p^{2} + 2k }[/tex]
I then do the same for the second to get
[tex]X_{2} = \frac{ k X_{1} }{ p^{2} + 2k }[/tex]
I then substitute [tex]X_{1}[/tex] into [tex]X_{2}[/tex], divide out [tex]F(p)[/tex], and then wind up with the transfer function
[tex]T(e^{jwt}) = \frac{ z^{-2} + 2kz^{-4} }{ 1 + 4kz^{-2} + 3k^{2}z^{-4} }[/tex]
My question:
Does this method work for finding the transfer function of coupled differential equations?
Sure, why not? All you're shooting for is [itex]T(p)=X_1(p)/F(p)[/itex], right? So if you can get there by this method (which you clearly can), then it must work!
  • · Replies 21 ·
