What is the Triangle Inequality in an Acute Triangle?
The discussion revolves around proving an inequality related to acute triangles, specifically the expression involving the sides of the triangle and their relationships. Participants explore methods and approaches to tackle this mathematical problem, which is framed within the context of inequalities in geometry.
  • One participant expresses a desire for advice and methods rather than direct solutions to the inequality involving the sides of an acute triangle.
  • Another participant questions the assumption that the right-hand side (RHS) of the inequality will be smaller for acute triangles and suggests starting by comparing polynomials.
  • A participant shares their reasoning, using an equilateral triangle as an example to support the belief that the inequality holds true.
  • Some participants suggest examining properties of acute triangles and considering why the inequality may not hold for non-acute triangles.
  • One participant mentions the potential relevance of Ono's conjecture and Heron's formula, indicating a connection to broader mathematical concepts.
  • Another proposes that proving each term in the inequality is less than or equal to 9 might be sufficient to establish the overall inequality.
  • A participant provides a mathematical manipulation to show that the inequality holds for equilateral triangles, while expressing the need to prove it for other cases.
  • There is a side discussion regarding interpersonal dynamics, with some participants expressing frustration over perceived condescension and miscommunication about problem-solving intentions.
  • One participant presents a detailed mathematical argument involving inequalities and the properties of acute triangles, though it is unclear if this aligns with the original request for help.
  • A participant reiterates their request for assistance rather than solutions, indicating a desire for collaborative exploration.
Participants do not reach a consensus on the best approach to prove the inequality. Multiple competing views and methods are presented, and the discussion remains unresolved regarding the validity of the proposed inequality for all acute triangles.
Some participants note the importance of properties specific to acute triangles, such as the positivity of certain expressions derived from the cosine law, which may not hold for triangles with angles greater than 90 degrees. There are also references to established inequalities that may provide insight but are not fully explored in the context of this problem.
Bitter
I am a beginner at trying to prove or disprove inequalities. In an attempt to improve on this skill I found some problems that I would like to work on. Now, I know many of you may be able to look at this and think of a solution, but please refrain from posting it, but some advice and methods would be helpful.
Prove that in any acute triangle ABC with sides a, b, and c, the following inequality is true. [tex]27 \leq (a+b+c)^2 \left( \frac{1}{a^2 + b^2 - c^2}+\frac{1}{b^2 + c^2 - a^2}+\frac{1}{c^2 + a^2 - b^2} \right)[/tex]
Mathematics news on Phys.org
Are you trying to say:
what have you tried?
Well, here is where I'm at. Well, I am fairly certain that this equation is true. If we exam the smallest acute triangle I can think of, an equilateral triangle whose sides are all one, then the solutions comes out to be exactly 27. So, that is where i am at right.
And what makes you think the RHS will be smaller for acute triangles?
I don't immediately see a clever way to do this, so I would start by multiplying out by a common denominator so that you're comparing polynomials, and then simplifying as much as possible.
mmm...problem like this is reminiscent of those you usuallly see in maths competitions or olympiad. It usually require some wit to do it elegantly. If you have absolutely no idea (like me currently :smile:), you should start by thinking about all the properties of an acute triangle and see whether that gives you other contraints relations between a, b, c. Next think about why it may not work for a triangle that is NOT acute (i guess that means it has one angle bigger than 90)
next, look at the expression itself (change its form) ...and see if you can recognise it or part of it from somewhere.. if not, see if you can find another inequality which is easier to handle that is bigger than or equal 27 yet less than or equal to original expression.
remember there are basic things like a + b > c, a + c> b, b + c > a. etc.
Using the cosine law, you can find an inequality for which an angle is acute. They talk about it here: http://mathworld.wolfram.com/AcuteTriangle.html"
given the similarity of the three terms in brackets, may be 27 really means 9+9+9, and proving that each term is [tex]9 \leq[/tex] may be sufficient... just a guess.
Certainly, acute angle means that Cos (any angle) is inside the open interval [tex](0,1)[/tex]
Let a=b a=c
27<_(a + a + a)^2((1/a^2) + (1/a^2) + (1/a^2))
27<_(9a^2)(3/a^2)
27<_27
So that proves that an acute triangle that happens to be an equilateral triangle is true, that means I just have to show that the rest hold true.
Yet another trivial problem you couldn't tackle ,ha Bitter ?:biggrin:
I'm not really sure what your problem is with me. I'm not even sure why you said yet again. The other problem I posted was not one I couldn't solve. I merely wanted to see other people's solutions to it. I just posted it in the wrong place and forgot about it. In fact, I'm fairly certain this is my first post about solving a problem in general math section.
So if you don't plan to give me advice that's fine, but if you feel the need to rub in the fact that you are better at math than I am, that's other thing.
Really?I don't recall I've seen you ever posted your solution..But never mind that.It was another problem anyway.I got an impression your main problem isn't math or misplacing the posts,but lazyness.Again,that's just my opinion.This time you posted the problem to the right place and you will see me post the solution.But only this time.
[tex]S=\frac{1}{a^2+b^2-c^2}+\frac{1}{b^2+c^2-a^2}+\frac{1}{a^2+c^2-b^2}\geq \frac{27}{(a+b+c)^2}[/tex]
(Firstly note the right side of ineq. is always positive-> left side must be always positive too.That is ensured ,becouse [itex]a^2+b^2-c^2>0,b^2+c^2-a^2>0,a^2+c^2-b^2>0[/itex]
is always true for acute triangles.Hence ,the restriction)
We have:
[tex]\frac{a^2}{a^2b^2+a^2c^2-a^4}+\frac{b^2}{a^2b^2+b^2c^2-b^4}+\frac{c^2}{a^2c^2+b^2c^2-c^4}=S \geq \frac{(a+b+c)^2}{2(a^2b^2+a^2c^2+b^2c^2)-(a^4+b^4+c^4)}=\frac{a+b+c}{(a+b-c)(a+c-b)(b+c-a)}[/tex]
Now we are left to prove that for a,b,c>0 the following is true:
[tex]\frac{a+b+c}{(a+b-c)(a+c-b)(b+c-a)}\geq \frac{27}{(a+b+c)^2}[/tex]
It's true becouse ,by Arithmetic-Geometric ineq,we have [itex](a+b+c)^3\geq 27abc[/itex] while [itex]abc\geq (a+b-c)(a+c-b)(b+c-a)[/itex] is obvious.
QED
EDIT:I can't be better mathematician than you.That's becouse I'm not a mathematician (per education) at all.
:smile:
Best regards
Sigh, I thought I said not to post an answer, but to help me out. Oh well...
