Evaluate ∫F∙dr: Surface Integrals Help
The discussion revolves around evaluating the line integral ∫F∙dr, where F is a vector field defined in three-dimensional space. The problem involves a triangular curve in the context of surface integrals and the application of Stokes' theorem.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to relate the line integral to a surface integral using the curl of the vector field. They express the normal vector and set up a double integral for evaluation. Some participants question the approach and suggest alternative methods, such as parametrization.
The discussion is active, with participants exploring different methods of evaluation. The original poster acknowledges a mistake in their reasoning, indicating a productive exchange of ideas. However, there is no explicit consensus on the best approach yet.
The problem is constrained by the requirement to evaluate the integral using a double integral approach, as specified by the original poster.
bodensee9
[Can someone help with the following? I am supposed to evaluate the line integral of ∫F∙dr. The curve is oriented counterclockwise as viewed from above. So suppose that F(x,y,z) = (x+y^2)I + (y+z^2)j + (z+x^2)k, and C is the triangle formed by (1,00), (0,1,0), (0,0,1).
I know that the integral ∫F∙dr over some surface S is equal to ∫∫curlF∙dS and is equal to ∫∫curlF∙n/|n|ds or ∫∫curlF∙ndA, where n is the normal vector. So, curl F is -2zi -2xj -2yk. And since the region has the expression x+y+z = 1, so suppose the region z can be written as (x, y, 1-x-y), and the normal vector to this region has the expression <dz/dx, -dz/dy, 1> or <-1,-1,1>. So wouldn’t curl F dot n be 2z+2x-2y, and since z = 1-x-y, curl F n should be 2-2x-2y+2x-2y? So I am supposed to integrate the integral ∫∫2-4y dydx where 0≤y≤1-x and 0≤x≤1? Can someone point out what I’m doing wrong here? Thanks.
i can't read all that, but couldn't you just check your work by simply parametrizing the triangle and just doing a one variable integral?
it is especially easy on the vertical and horizontal dies where, on the y-axis side say, both dx and dz are zero.
But I'm supposed to evaluate it using the double integral, so.
The plane equation is, indeed, x+y+z=1.
Hence, the normal vector is parallell to (1,1,1)
Oh I see where I went wrong! Thanks!
