Thread Closed
inclined ramp problem
Share Thread Thread Tools
Feb9-07, 12:32 PM   #1
A block of mass 2.1 kg is placed on a frictionless inclined ramp of mass 20.0 kg, with the angle θ= 31o as shown below.
Calculate the size of the net horizontal force that must be applied to the ramp to prevent the block from accelerating with respect to the ramp?
2. Relevant equations
mgsin(theta) = F of the small block
3. The attempt at a solution
i've used the data to find the acceleration of the small block (5.0474). but i'm not sure where to go from there. i've tried multiplying by the mass of both block and that didn't work. anyone want to help?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Feb9-07, 12:49 PM   #2
Mentor
Quote by mcstink View Post
You've calculated the acceleration (parallel to the incline) that the small block would have if it slid down a fixed frictionless ramp--but that's not relevant here. (After all, you are trying to prevent the small block from sliding down.)
Hint: Start by analyzing the forces acting on the small block.
Feb9-07, 12:52 PM   #3
Start with drawing a free body diagram and identifing all the forces.
Look at:
[tex]\sum F_{x}=\\w_{x}\\-f_{s}=\\0[/tex]
[tex]\sum F_{y}=\\n_{y}-\\w_{y}=\\0[/tex]
and [tex]f_{s}=\\u_{s}\\n[/tex]
Feb9-07, 01:13 PM   #4
okay i'm not quite sure i know all of those abbreviations.
but i think the only forces acting on the small box is the force as it slides down the plane (from gravity) and the force from the ramp from it being pulled. the normal force cancels out with mgcos(theta) and there is no friction. how would i set this up?
Feb9-07, 01:18 PM   #5
force from gravity is weight and it acts all the time not only as it slides down...
use Newton's II Law,
and, yes there are only 2 forces
Feb9-07, 01:19 PM   #6
Mentor
Right. There are two forces acting on the small box: gravity and the normal force from the ramp.
Not sure what you mean here.
Hint: The vertical component of the normal force must balance the weight of the small box, since it has no vertical acceleration.
Your first goal is to find the acceleration that the small box must have for it not to slide down the ramp.
Feb9-07, 01:23 PM   #7
Well,
Since: [tex]\sum F_{x}=\\w_{x}\\-f_{s}=\\0[/tex] Newtons First Law because we want no net force/accleration
[tex]f_{s}=\\w_{x}[/tex]
[tex]f_{s}=\\mgsin(\theta)[/tex]
Feb9-07, 03:08 PM   #8
Mentor
Quote by Weave View Post
Well,
Careful about using the ramp as a reference, which I think is what you are doing here. Since the ramp is accelerating it is a non-inertial frame.
Feb3-08, 06:09 PM   #9
hi i'm having trouble with this question s well, though i have different numbers. but just in terms of setting it up, i was able to calculate the vertical forces acting on the small block, but what is the acceleration supposed to be?
I have
Fy=F_s - mgsin(theta)=ma
what is a supposed to be? 0? I think it should be 0, because you want zero acceleration, but then what to do with the ramp forces..?
Feb3-08, 06:10 PM   #10
or should the accelerations of the block and ramp be the same?
Thread Closed
Thread Tools
Similar Threads for: inclined ramp problem
Thread Forum Replies
Maximum velocity of a car leaving inclined ramp. Introductory Physics Homework 1
Friction on an inclined ramp Introductory Physics Homework 2
inclined ramp inside an accelerating train Introductory Physics Homework 5
Need help - ramp problem inclined plane General Physics 1
