How to Solve a Second Order Differential Equation with a Trigonometric Function?
  • Thread starter Thread starter peacex
The discussion revolves around solving a second-order differential equation involving a trigonometric function, specifically x'' = cos(x). Participants express confusion regarding the methods to approach this type of problem.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss various methods to reduce the order of the differential equation, including using relationships between derivatives and applying the chain rule. There is also mention of integrating factors and the importance of the constant of integration.
The discussion includes multiple interpretations of the approaches suggested, with some participants affirming the correctness of earlier suggestions while others express skepticism. There is an ongoing exploration of the implications of different methods and the necessity of constants in integration.
Some participants question the assumptions made in the derivations and the validity of certain mathematical transformations. The presence of trigonometric functions adds complexity to the problem, leading to discussions about the nature of solutions and potential use of elliptic integrals.
peacex
im new to 2nd order differential eqns and I am getting myself all confused.
ive tried so hard but i just can't solve it.
can someone please help me with tips to solve/solutions?
x'' = cos(x)
Try using [tex]\ddot{x} = \dot{x}\frac{d\dot{x}}{dx}[/tex]
That will allow you to turn it into a first order equation at the very least.
thankyou! i didnt think of that!
I don't think that's correct.
You should have written
[tex]\ddot{x}=\frac{1}{\dot{x}}\frac{d}{dt}\left(\frac{\dot{x}^{2}}{2}\right)[/tex]
No, Dextercioby, the first response was correct. If you let u= dx/dt, then du/dt= d2x/dt2. But we can apply the chain rule to the left side: du/dt= (du/dx)(dx/dt)= u du/dx since u= dx/dt. d2u/dt2= u du/dx.
This method is called "quadrature" (because the integral involves u2) and can be used to reduce the order of a differential equation when the independent variable, t, does not appear explicitely in the equation.
x" = cosx
its x-missing
v = x'
v' = x" = v dv/dx
v dv/dx = cosx
vdv = cosx dx
v^2 = 2 sinx
(x')^2 = 2 sinx
x' = ( 2 sinx )^1/2
dx / (sinx )^1/2 = 2^1/2 dy
Q = 2^1/2 y + C
such that Q = http://integrals.wolfram.com/index.jsp
You cannot neglect the constant of integration.
if
[tex]y^{\prime \prime} = \cos{y}[/tex]
multiply by [tex]y^{\prime}[/tex]
gives you
[tex]y^{\prime} y^{\prime \prime} = y^{\prime} \cos{y}[/tex]
integrate, and you get
[tex]\frac{1}{2}y^{\prime 2} = \sin{y} + C[/tex]
Note the constant of integration which must not be ignored.
Therefore, you have
[tex]y^{\prime} = \sqrt{2 \sin{y} + C}[/tex]
which isn't easily soluble -- the only way to get an answer is to use elliptic integrals -- have a look at this Wolfram page.
It can't be, since [tex]\frac{d\dot{x}}{dx}=0[/tex].
Where in the world did you get that idea?
If x(t)= et, then x'= et= x. In other words,
[tex]\frac{dx'}{dx}= 1[/tex]
not 0.
  • · Replies 33 ·
