Volume of a Solid by Revolution
The problem involves finding the volume of a solid obtained by rotating the region bounded by the line equation y=8*x+32 and the x-axis about the y-axis. Participants are exploring the setup and calculations related to this volume of revolution problem.
  • Participants discuss different methods of setting up the integral for the volume, including solving for x and integrating with respect to y. There are questions about the correctness of the limits and the interpretation of the rotation about the y-axis.
Some participants express confidence in their calculations, while others question the validity of their answers based on external sources. There is an ongoing exploration of potential errors and different approaches to the problem, with no clear consensus on the correct solution.
Participants note that the problem may involve issues with significant digits or misunderstandings about the setup for rotation. There is mention of a discrepancy between their answers and those found on an external webpage.
Sidew
Hi, the next problem I thought it was easy...and I really think it is, but I haven't come with the right answer :S. I compare the answer in an internet page of problems and all it says is "wrong"...
The problem is the following:
Find the volume of the solid obtained by rotating the region bounded by
y=8*x+32, y=0 about the y-axis.
I made the sketh in Maple:
http://img109.imageshack.us/img109/5669/solidvolumexi5.th.jpg
Then I solve for x:
x=(y/8)-4
and wrote the Integral with respect to y, and limits from 0 to 32 (where the function y=8x+32 intersects the y-axis).
Integral of Pi*f(x)^2, from y=0 to y=32, it should give me the volume, isn't it?
http://img164.imageshack.us/img164/98/equationie6.th.jpg
My answer: 512/3 * Pi= 536.1651462
But the internet page says I'm wrong but I don't know why :S
Any help is welcome, Thanks in advance!
Your answer looks right. I'd say the super trustworthy internet is wrong ;). (Disclaimer: I'm getting back into calc after a year of none, but still I'm quite sure you're correct).
Possibly: Integration of Pi * (8x + 32)^2. -4 (lower limit) and 0 (upper limit)
Thanks to all of you for your answers.
AngeloG, I already tried what you suggest and I came with the answer:
4289.321169 which is wrong as well.
And because the region should be rotated about the Y-Axis and not about the X-axis, that's why I solved the equation for X, in order to have only Y's so I could integrate with respect to dy, then my limits are Y=0 and Y=32.
I hope I didn't understand you another thing, maybe "4289.321169" wasn't what you get, so I would like to know your answer.
Thx again^^, cheers!
Err, forgot to say change the x's for y's and the y's for x's.
8x + 32 is basically the same as 8y + 32. One is just tilted on it's side, which is the y. Then you can integrate from -4 to 0, then rotate it around y-axis tilted.
(4096 / 3) * Pi, which is ~4289.3
However, I am wrong =). I was just doing the other half, considering your half was wrong. There's only two ways to do this and if both provide the wrong answer. Might be the page.
y= 8x+ 32 is a straight line with intercepts (0, 32) and (-4,0), rotating around the y-axis gives a cone with height 32 and radius 4. you can check the volume by using the standard formula for volume of a cone: [itex]V= \frac{1}{3}\pi r^2h[/itex].
Thx again for all your answers^^, I didnt know there will be so many options or ways to solve the problem.
AngeloG, thanks for your reply.
HallsofIvy, I tried that :O, and I got: 536.1651462, but the page says its wrong -.-, so now I'm almost sure that is the webpage.
cheers!
It might be a significant digits problem. Did you try just "536"?
  • · Replies 34 ·
