Electric Trains and The Third Rail
  • Thread starter Thread starter Elektrotechniker
    Electric Trains
The discussion centers on the operation of electric trains using a third rail system for power delivery. It clarifies that return current typically flows through the running rails, not the ground, which is a common misconception. The conversation highlights that while one rail may serve as a return path, the other can be at ground potential, allowing safe contact without shock. The discussion references the London Underground's unique fourth rail system as an example of alternative configurations.
  • Understanding of electric train systems, specifically third rail technology.
  • Basic knowledge of electrical circuits, including current flow and potential difference.
  • Familiarity with railway infrastructure, including running rails and their functions.
  • Awareness of safety protocols related to high-voltage systems.
  • Research the operational principles of third rail systems in electric trains.
  • Explore the design and functionality of the London Underground's fourth rail system.
  • Study the differences between rubber-tired and steel-wheeled metro systems.
  • Investigate safety measures and protocols for working around high-voltage rail systems.
Electrical engineers, railway system designers, safety inspectors, and anyone interested in the mechanics of electric train operations.
Elektrotechniker
So we're always told not to touch the third rail, as it's at a very high potential. Makes sense.
But how does return current work in such a system? Let's say there is some load (the motor - we'll simplify and assume DC). One terminal of the motor is connected to the third rail, what's the other end connected to? My friend theorizes ground... but that seems wrong to me. You can't just charge up the Earth through the motor... can you? Could that work? Why not?
It seems to me one of the rails ridden upon must be used for return current - and this would seem to imply that if you were between the train and the generator and you touched said rail, you'd be electrocuted.
I would assume that one of the other two rails would be ground. Since they are at ground potential, you would not get shocked if you touch it because your body is also at ground potential. All electricity, theoretically does return through the earth. Consider it as a huge bathtub full of electrons. You can pull some out and put some in.
The same principle is in a simple circuit. If the circuit is energized, you can most likely touch the GND side of the circuit without getting a shock. If you were to touch the "hot" side, you would get a zap because there would be a difference in potential between you and the ground you're standing on.
Wikipedia has a good article on it: http://en.wikipedia.org/wiki/Third_rail
"As with overhead wires, the return current on a third-rail system usually flows through one or both running rails, and leakage to ground is not considered serious. Where trains run on rubber tires, as on parts of the Paris Métro, Mexico City Metro and Santiago Metro, as well as on all of the Montréal Métro, live guide bars must be provided to feed the current. The return is affected through the rails of the conventional track between these guide bars (see rubber-tired metro). Another design, with a third rail (current feed, outside the running rails) and fourth rail (current return, half way between the running rails), is used by a few steel-wheel systems. The London Underground is the largest of these, see Fourth Rail."
So it does depend on the type of system in place, but the running rails are often used as returns.
