Is dG Always Equal to Maximum Work in Thermodynamics?
The discussion revolves around the relationship between Gibbs free energy (dG) and maximum work (dW) in thermodynamics. Participants are exploring whether the equation dG = dW holds true in general and are examining specific conditions under which it might apply.
  • Participants are questioning the validity of the relation dG = dW and discussing its applicability in specific scenarios. There are attempts to derive relationships involving pressure and volume changes, as well as surface tension, in the context of Gibbs energy.
Some participants have provided references for further reading, while others are clarifying the assumptions behind the equations being discussed. There is an acknowledgment that the relation dG = dW is not universally valid, and the conversation is exploring the nuances of its application.
There is a mention of specific conditions under which the relation might hold, such as when work is fully resisted. Participants are also reflecting on potential mistakes in their reasoning regarding the relationships between pressure, volume, and Gibbs energy.
mjbm0720
Hi
I am new in thermodynamics , and I thought you can help me
If it is valid dG=dW
May I say
dG=-Pdv
P=-dG/dv?
thanks in advance,Mariana
P=external pressure
G=Gibbs energy
W=maximum work
Hi mjbm0720, and welcome to the forums.
mjbm0720 said:
Hi
This relation is NOT valid in general at all.
However, assuming that the relation is valid in a specific situation,
dG=-Pdv
P=-dG/dv?
seems to be correct, assuming that the work done is fully resisted.
Is there anything specific you are trying to show?
Thank you so much
I was trying to show this:
Because of dG=dWmax and dw=surface tension por dA
Surface tension=dG/dA
I was thinking because dw=pdV
I could say
p=-dG/dV
But I see that it is a mistake
  • · Replies 16 ·
