Thread Closed
heat of formation of nh4cl
Share Thread Thread Tools
Feb12-07, 02:16 PM   #1
i did a lab calorimeter lab with 50ml 1.51M nh3 and 50ml 1.59M hcl yeilding nh4cl (aq)
the deltaT was 8.6 degC
second part is 100ml of h2o and 4.082g nh4cl
deltaT was -2.8 degC
2. Relevant equations
how do i find deltaH per mole for each reaction?
3. The attempt at a solution
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Feb12-07, 04:22 PM   #2
Other Sciences 2012
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Give us your try at the answer.....
Hint: Write out the reactions for the first part and the second part. What form was the ammonia? Was it aqueous? How should that be written?
Feb12-07, 07:45 PM   #3
its nh3(aq) + hclz(aq) = nh4cl(aq)
and nh4cl(s) = nh4cl(aq)
but where do i go from there?
Feb13-07, 08:53 AM   #4
Other Sciences 2012
Recognitions:
NH3 in water is NH4+ OH-
HCl in water is H3O+ Cl-
one of the two reactions is:
NH4+(aq) + Cl-(aq) ----> NH4Cl(aq)
Can you determine the other reaction?
You will need the heat capacity of the ammonium chloride solution. Can you determine what the concentration will be?
Alternatively, you could assume the heat capacity of pure water, but it won't be an exact solution. Can you think of why you need to obtain the heat capacity?
Thread Closed
Thread Tools
Similar Threads for: heat of formation of nh4cl
Thread Forum Replies
Heat of formation? Biology, Chemistry & Other Homework 3
Standard Heat of Formation of Uranium Compounds Classical Physics 0
Delta Heat of Formation Chemistry 2
Standard Heat of Formation Question Biology, Chemistry & Other Homework 6
Why is the heat of formation for NaOH negative? Chemistry 2
