Compactness of a Set S in a Normed Vector Space E
  • Thread starter Thread starter tghg
The problem involves demonstrating the compactness of a set S in a normed vector space E, where S consists of a limit point v and a sequence {Xn} that converges to v. The original poster attempts to understand the implications of compactness and the behavior of sequences within the set.
  • Participants discuss the definition of compactness, particularly focusing on the existence of convergent subsequences within sequences drawn from S. There is an exploration of the nature of accumulation points and the boundedness of the set S.
Some participants suggest examining the properties of accumulation points and the implications of sequences containing either a finite or infinite number of distinct elements. There is a focus on the relationship between the elements of S and their convergence to the point v, with various lines of reasoning being explored without reaching a consensus.
Participants question whether the set S is bounded and discuss the implications of open covers in relation to the compactness of S. The discussion reflects on the definitions and properties relevant to the problem without resolving the questions raised.
tghg
Serge Lang Undergraduate Analysis Chapter Ⅷ §1 Exe4
Let{Xn} be a sequence in a normed vector space E such that {Xn} converges to v. Let S be the set consisting of all v and Xn.
Show that S is compact.
None
I guess that maybe it is useful to consider it from the aspect of the definition of compactness,i.e. every sequence of elements of S has a convergent subsequence whose limit is in S. But I coudn't convince that why there must be such a convergent subsequence in every sequence, you know, some sequences are not the given ones that converge.
Here's a plan for you.
1° Show that the only accumulation point in S is v.
2° Consider a sequence {a_n} in S. Convince yourself that there can be one of two possibilities. Either {a_n} contains a finite number distinct elements or an infinity of distinct element.
3° Show that in the first case, there is at least one element of the sequence that appears an infinity of times (this defines a converging subsequence).
4° Show that in the later case, the sequence is convergent and converges to v. (defining a "trivially converging" subsequence)
Thanks.
but I still have some problems.
I can't show that
If {a_n} contains an infinity of distinct element, the sequence is convergent and converges to v.
Is the set S bounded?
It's probably easiest to go back to the definition in terms of open covers. If U_alpha is an open cover, v is in one of the open sets, and this open set contains all but finitely many of the x_n.
This point raised by StatusX (namely, that If U_alpha is an open cover, v is in one of the open sets, and this open set contains all but finitely many of the x_n), is also the key to your problem:
I can't show that
The fact that v is the only accumulation point of S means that
[tex]\forall\epsilon>0, \ \ |S\setminus (B_{\epsilon}(v)\setminus\{v\})|<\infty[/tex]
In words: for any radius epsilon as small as we like, there is only a finite number of elements of S outside the open ball of radius epsilon centered on v.
It follows immediately that for any sequence {a_n} with an infinity of distinct elements and for all epsilon>0, there exist an N>0 such that for all n>N, a_n [itex]\in B_{\epsilon}(v)\setminus\{v\}[/itex] and that is precisely the definition of convergence.
(If it weren't so, i.e. if there was an epsilon such that there is only a finite number of elements inside the epsilon-ball, then there is an infinity of them outside. But there is only a finite number of distinct elements outside the epsilon-ball, so our sequence cannot have an infinity of distinct elements: contradiction.)
  • · Replies 26 ·
