Producing Nickel Crystals: B & D are Correct Answers
  • Thread starter Thread starter pivoxa15
    Crystals Nickel
The discussion revolves around the methods for producing nickel crystals from nickel sulfate (NiSO4) through various chemical reactions. Participants explore different options provided in a homework question, analyzing the feasibility of each method based on reduction potentials and chemical reactions.
  • Homework-related
  • One participant suggests that both zinc (Zn) and potassium (K) could act as reductants to produce nickel crystals from NiSO4, while also considering electrolysis as a viable method.
  • Another participant argues that potassium's reaction with water would prevent nickel crystal formation, asserting that the reaction produces potassium hydroxide and potentially leads to nickel hydroxide precipitation.
  • A later reply emphasizes that potassium reacts violently with water, producing a high pH solution that could affect nickel's solubility.
  • Concerns are raised about the validity of electrolysis of molten NiSO4, with one participant stating that NiSO4 decomposes before melting, questioning the correctness of this method.
  • There is a mention of the gases produced during the reaction, with some participants speculating on the possible byproducts of potassium's reaction with water and nickel.
Participants express disagreement regarding the correctness of the methods proposed for producing nickel crystals, particularly concerning the role of potassium and the electrolysis of NiSO4. No consensus is reached on which methods are definitively correct.
Some assumptions about the reactions and conditions are not fully explored, such as the specific behavior of nickel in high pH environments and the implications of potassium's reaction with water. The discussion also highlights the potential decomposition of NiSO4, which may affect the validity of electrolysis as a method.
pivoxa15
Which two of the following could be used to produce crystals of nickel?
A Addition of a piece of copper to a NiSO4
B Addition of a piece of zinc to a NiSO4 solution.
C Addition of a piece of potassium to a NiSO4 solution.
D Electrolysis of molten NiSO4.
The reaction should change (Ni)2+ to Ni so (Ni)2+ must be reduced by accepting electrons from the added metal. So the piece of metal should act as a reductant.
From the tables
(Cu)2+ + 2e --> Cu (+0.34)
(Ni)2+ + 2e --> Ni (-0.23)
(Zn)2+ + 2e --> Zn (-0.76)
(K)+ + 2e --> K (-2.93)
It looks like both Zn and K are worthy candidates as the reductant and produce nickel crystals.
If we look at D, we can see that out of the three species in the electrolyte, (Ni)2+, (SO4)2- and H2O the strongest oxidant is (Ni)2+ and the strongest reductant is H2O because
O2 + 4H+ + 4e --> 2H2O (+1.23)
(S2O8)2- + 2e --> 2(SO4)2- (+2.01)
(SO4)2- and H2O as oxidants are weaker than (Ni)2+ because
2H2O + 2e --> H2 + 2(OH)- (-0.83)
(SO4)2- + H2O + 2e --> (SO3)2- + 2OH- (-0.93)
So it is possible to produce nickel crystals via electrolysis. Hence B,C,D are all possible solutions but the solutions only had B,D as the correct solution. Why isn’t C correct? Although I notice the question did specify that there are two correct answers, there seems to be an extra one.
The solution in C contains water. What happens when potassium contacts water?
There is no water in "molten NiSO4". Actually, there is no such thing as molten nickel sulfate since it decomposes at its melting point to NiO and a gas. So, D is actually a wrong answer. (Can you figure out what the gas(es) might be?)
The only reasonable answer is B.
When K contacts H2O, the K will act as a reductant and H2O as an oxidant hence react with each other. But K will also react with Ni so Ni crystals will also be formed. Ni is a stronger oxidant than H2O.
The gases would be sulphur trioxide. And sulphur oxide and oxygen.
Potassium will indeed react with water. The potassium explodes into molten white-hot purlpish flames and dances and skitters over the surface of the water. The result is potassium hydroxide solution and perhaps some small secondary fires here and there. The pH of the solution will afterwards be 14+. What will happen to nickel in solution at this pH? My Merck says that nickel hydroxide is "insol in water".
What is 'Merck'? So nickel hyroxide or Ni(OH)2 will precipitate into a solid in water. Hence no nickel solids will form. In this case K has created the exitence of OH- which will react with Ni and form a solid.
"The Merck Index", 11th ed. (1989), ISBN Number 911910-28-X
From the Editor's preface:
"In the 100 years since the Merck Index was first published in 1889, it has evolved from a 170-page alphabetic catalog of chemicals and drugs sold by Merck, into an authoritative and widely quoted 2300-page multidisciplinary encyclopedia."
Susan Budavari, Editor
Merck Sharp & Dohme Research Laboratories
Rahway, New Jersey 07065
12K
13K
9K
25K
