Can an Indestructible Vacuum Globe Float in the Atmosphere?
  • Context: Undergrad
  • Thread starter Thread starter rabbitandcrow
    Vacuum
An indestructible, impermeable globe containing a complete vacuum will rise into the atmosphere when its size is increased sufficiently. The key principle at play is Archimedes' principle, which states that the buoyant force acting on the globe increases with its volume, while its weight remains unchanged. Once the buoyant force exceeds the gravitational force acting on the globe, it will ascend. The internal pressure of the globe does not influence this outcome.
  • Understanding of Archimedes' principle
  • Basic knowledge of buoyancy and gravity
  • Familiarity with gas physics concepts
  • Comprehension of pressure dynamics in a vacuum
  • Research Archimedes' principle in depth
  • Explore the physics of buoyancy and its applications
  • Study the properties of gases and vacuums
  • Investigate the relationship between volume, weight, and buoyant force
Students of physics, educators teaching gas dynamics, and anyone interested in the principles of buoyancy and atmospheric physics will benefit from this discussion.
rabbitandcrow
I've done my own head in - all because I didn't study basic gas physics hard enough. So...
Assume I have an indestructible, impermeable, rigid globe (of a fictional metal, say) containing a complete vacuum, and I am able to change the size of the sphere at will. My globe and I are standing at sea level. If I keep increasing the size - and so, volume - of the globe, will the globe eventually rise upwards into the atmosphere?
It will, right?
I guess the fact that the pressure inside the globe is always zero is kind of throwing me, for some reason.
Science news on Phys.org
Yes it will.
If your assumptions hold, when you increase the size of the globe, it will finally rise upwards into the sky. Because the total weight of the globe is unchanged, and the Archimedes increases when the volume of the globe increases, so you will get to the point that the archimedes force exceeds the gravity of the globe. Pressure inside the globe has nothing to do in this case.
Right. Good. Thank you very much.
It's a buoyancy thang! I completely understand now. Sometimes all you need to solve a problem is the right word to put in the wikipedia search. In this case, "Archimedes".
Again, thanks.
  • · Replies 32 ·
10K
  • · Replies 16 ·
