Infinite resistance of a Voltmeter
The discussion revolves around the concept of voltmeter resistance in relation to circuit measurements, particularly in the context of potentiometers. The original poster seeks clarification on why a voltmeter's resistance should be significantly higher than the circuit resistance to avoid altering the measured potential difference.
  • Participants explore the implications of voltmeter resistance on circuit behavior, with suggestions to visualize the problem through circuit diagrams. Questions about the definitions and practical usage of measuring devices are also raised.
Some participants have provided insights into the importance of voltmeter resistance and its effect on circuit measurements. There is an acknowledgment of the need for the original poster to engage more deeply with the topic, but no explicit consensus has been reached.
There are references to guidelines for participation in the forum, emphasizing the importance of demonstrating effort in understanding the concepts before seeking help.
shehri
While studying about 'Potentiometer' it's said :
"The resistance of the voltmeter be large compared to the circuit resistance across which the voltmeter is connected.Otherwise an appreciable current will flow through voltmeter which will alter the circuit current & the P.D to be measured". Can anybody explain this concept?.Thanks.
The concept is actually straight forward. You need to show some thought about your question before we can help you. (see https://www.physicsforums.com/showthread.php?t=94379)
If you are truly lost, you might begin by defining some of the terms or if it is a measuring device, how do you normally use this in the lab. Have you done any research about this, on the web? (hint: use search engines)..
Think of two circuits each with a battery and a two equal resistors of say 1kohm, one where you are measuring the voltage across a resistor with a high resistance voltmeter say 1Mohm and one where you measure with a low resistance voltmeter say 1ohm. Draw out the circuits and see if you can work out what the voltage measured in each case would be and what the actual voltage should be.
Because "an observer disturbs the system he/she is trying to observe", it is important to include a measuring device in a such way that only minimal change to the original system results. In the voltmeter case, you are providing the current an alternative pathway to flow once you have introduced the voltmeter in the circuit. Hence, in order to minimise the amount of currrent using this path (created by the inclusion of the voltmeter) you want the resistance of the voltmeter to be very large compared to the circuit component it is measuring. Higher resistance means that most of the current will follow the original path and hence leads to minimal change to the circuit conditions.
I know both of you, are trying to be helpful to shehri, and you have not earned "homework helper" badges yet. It would be more helpful to the person asking the question, to show they have given some thought to them and not just seeking answers from the PF community.
You are encouraged to read this https://www.physicsforums.com/showthread.php?t=94379 which outlines what is expected of posters to the homework section.
Thanks for clearing me about 'infinite resistance' in a simple manner.Especially 'mjsd'.Thanks once again.
15K
