Change in Pendulum's Period with temperature.
The relationship between temperature increase and the change in the period of a simple pendulum is defined by the formula delta(P) = 1/2*alpha*Pinitial, where alpha represents the coefficient of linear expansion. The period of the pendulum is given by the equation P = 2*pi*sqrt(L/g). As temperature changes, the pendulum length adjusts to L + alpha*L*delta(T), leading to a new period that can be expressed as delta(P) = Pinitial*(sqrt(1 + alpha*delta(T)) - 1). To simplify the calculations, a binomial expansion can be employed.
  • Understanding of simple harmonic motion and pendulum mechanics
  • Familiarity with the coefficient of linear expansion (alpha)
  • Knowledge of basic calculus for simplification techniques
  • Experience with mathematical notation, particularly in physics
  • Research the application of binomial expansion in physics problems
  • Study the effects of temperature on material properties, focusing on linear expansion
  • Explore the derivation of the period of a pendulum in varying conditions
  • Learn to use LaTeX for writing and formatting mathematical equations
Students and educators in physics, mechanical engineers, and anyone interested in the dynamics of pendulums and thermal effects on physical systems.
rmorelan
Hi! I have been racking my brain trying to solve the relationship between the effect of temperature increase and the change in period of a pendulum. I am suppose to prove a relationship, and am given that the relationship is
where alpha is the coefficient of linear expansion with temperature.
We are given that we are dealing with a simple pendulum, so the period is equal to 2*pi*sqrt(L/g)
I know the pendulum length will change under change of temperature to alpha*L*delta(T), for a total new length of L+alpha*L*delta(T)
the change in period then I would guess is:
delta(P) = 2*pi*sqrt((L+alpha*L*delta(T)/g) - 2*pi*sqrt(L/g)
I have tried to simplify this a dozen different ways but I never seem to get the required end formula. I think I can pull out Pinital by dividing everything by 2*pi*sqrt(L/g) to get
delta(P) = Pinitial*(sqrt(1+alpha*delta(T))-1)
but am stuck after that.
thanks for any help!
p.s. is there a summary list for the symbol set this forum uses to generate symbols like pi, square roots etc?
That relationship isn't quite right. How can the change in period be independent of change in temperature? (A delta(T) is missing.)
You've got it. Hint: Approximate the answer using a binomial expansion.
The best way to write equations is using Latex: https://www.physicsforums.com/showthread.php?t=8997"
Great! Thanks, how do to anything with that sqrt term was driving me nuts!
  • · Replies 20 ·
  • · Replies 32 ·
