Geodesics inside a spinning ball of the gravitational field matter
The discussion centers on the behavior of geodesics within a spinning ball of gravitational field matter (gfm), highlighting that the linear velocity of rotation is greater at the edge than at the center. According to Einstein's theory of the spinning disk, spacetime curvature is more pronounced at the edge, causing geodesics to curve inward. This results in an acceleration towards the center in the outer part of the gfm ball, while the central region exhibits asymptotic freedom. Additionally, time dilation and mass increase occur in the outer part of the gfm ball.
  • Understanding of Einstein's theory of relativity
  • Familiarity with concepts of spacetime curvature
  • Knowledge of gravitational field matter (gfm)
  • Basic principles of geodesics in physics
  • Research Einstein's theory of the spinning disk
  • Explore the implications of spacetime curvature on gravitational fields
  • Investigate time dilation effects in rotating systems
  • Study the concept of asymptotic freedom in physics
Physicists, researchers in gravitational theory, and students studying advanced concepts in general relativity and spacetime dynamics.
Zhang Xu
The linear velocity of rotation of a spinning ball of the gravitational field matter (gfm) is faster at its edge than in its central part. According to Einstein's theory of the spinning disk, the spacetime curvature at the edge of the gfm ball is larger than that in the central part; and geodesics inside the gfm ball curve towards the centre. Hence in the outer part of the gfm ball, there exists an acceleration directing towards the centre; there exists the asymptotic freedom in the central part of the gfm ball; and in the outer part of the gfm ball, time dilates and mass increases.
For more information, please see Chapter 6 of the Antigravitation Engine Site (http://xczhx.nease.net/indexEnglish.htm ).
Could you maybe elaborate on the 'FOGGOID STATE' it appears to be a bit murky?
I have read the theory, and must admit that I am not at all convinced of it's ability to perform as described with respect to gravity, as many "tricks" can be done with motion if there is a surface contact(device-to-water).
So, I offer a challenge:
Construct the device, but instead of using water, why not simply suspend it in air from a string like a pendulum(surely that scenario has LESS resistance than water). Then, if the device when activated goes to and maintains a position off-center, you have something. If not, you don't, and the theory is false.
Surely this SIMPLE experiment is a worthy proof-of-concept, MUCH MORE SO than with a water-based experiment.
Challenge accepted?
  • · Replies 16 ·
  • · Replies 20 ·
  • · Replies 18 ·
  • · Replies 57 ·
