Spectrum flip dependent on background
  • Context: High School
  • Thread starter Thread starter ktoz
    Spectrum
The discussion revolves around the phenomenon of spectrum flipping when viewing black and white bars through a prism. Participants explore the optical effects observed when the orientation of the bars is changed, considering both theoretical and experiential perspectives on light behavior and color perception.
  • Ken describes observing a spectrum flip when viewing a black bar on a white background versus a white bar on a black background through a prism, noting the colors appear to switch positions.
  • Claude suggests that the white bar could be conceptualized as a gap between two black bars, potentially affecting the observed spectrum.
  • Ken conducts further observations with a half black, half white sheet of paper and notes distinct color patterns that emerge, questioning the reasons behind the disappearance of certain colors in each orientation.
  • Ken proposes two hypotheses to explain the observed effects: one involving the overpowering nature of white light and another involving phase cancellation of light reflecting off surfaces.
  • Another participant explains that the prism deflects blue light more than red light, leading to overlapping images that can appear white due to the combination of colors at the edges.
  • A later reply references Goethe's rejection of Newton's theory, suggesting that color arises from the interaction of light and dark rather than being solely a property of light itself, drawing parallels to Ken's observations.
Participants express various hypotheses and interpretations regarding the observed spectrum flip, with no consensus reached on the underlying cause of the phenomenon. Multiple competing views remain, particularly regarding the nature of color perception and the effects of light and dark boundaries.
Participants acknowledge the complexity of the phenomenon, with discussions touching on the limitations of their observations, the dependence on definitions of color, and the unresolved nature of the mathematical or physical principles at play.
ktoz
Hi
This is probably pretty basic but I've asked a few times in various internet forums over the years and never gotten an answer.
If you print a black bar on a white packground and a white bar on a black background and view each bar through a prism, held at the same angle, the spectrum flips. I don't have a prism on hand so forget the color order but this is basically what you see at the transitions from black to white.
black bar/white background
red-----------------------blue
white bar/black background
blue----------------------red
I'm a sculptor by training so have only a rudimentary knowledge of optics but for all appearances, it would seem that red and blue light follow the exact same path through the prism (are refracted the same) depending on whether the background is dark or light. Can anyone explain the cause of this spectrum flip?
Thanks
Ken
Science news on Phys.org
Cute. Does it help you to think of the white bar like the gap between two black bars?
The black bar/white background case will act like a two white bars, with a black bar in between them. What you are therefore seeing is most likely the blue end of the spectrum from one white bar and the red end from the other white bar sandwiched together.
Claude.
Claude.
Thanks for the response Claude.
In order to double check my old observations, I dug out my prism from storage and looked again, this time with a sheet of paper half black and half white. This eliminates the "sandwich effect" you mentioned above while still showing spectrum flip.
Holding the prism so the apex points to the right
For white left/black right you see
white cyan blue violet black
For black left/white right you see
black red orange yellow white
I'm not claiming anything Earth'shaking here, I just find it curious how the simple act of rotating a piece of paper 180 degrees can so effectively shift color from the blue end of the spectrum to the red end. For white/black the red end of the spectrum is completely absent. For black/white the blue end is absent.
View angle doesn't seem to matter as there is no detectable color change with change in viewing angle with either orientation. So it's not just a matter of the blue spectrum or red spectrum not being focused into your eye. They seem to disappear completely.
The only things I can think of to explain this effect are:
1. The white is overpowering the hidden end of the spectrum
2. There is enough light reflecting off the white surface that is exactly i/4 wavelength out of phase to cancel the missing end of the spectrum.
Option 1 seems plausible except (especialy noticeable in the case of white cyan blue violet black) the line between white and cyan is fairly sharp. I would expect to see yellow, orange, red fade in intensity but that's not what you see. You see white, bam, cyan.
Option 2 seems plausible except there wouldn't seem to be any logical reason why this 1/4 out of phase light would selectively restrict one end of the spectrum.
Ken
Rotation? Phase? Will it help if I draw a picture?
Code:
  black bar/white background           black bar/white background
red-----------------------blue      red-----------------------blue
                          blue------red
Code:
                          blue------red
Thanks. But there's no need for sarcasm. If you look at my first post, you''ll see an almost identical diagram, so yes, I am aware of this relationship. The question was not what was being observed, but why.
One half of the spectrum disappears and that disappearance has some logical cause. Angle in the prism, phase cancellation, something That's what I'm trying to find out.
Ken
Your prism is deflecting all the blue light to the left, and the red light not so much to the left (and colours in between stay that way). If your light source was just a pin point, you'd get a pretty spectrum (since the colours would no longer overlap). Since you're using an extended source, you should instead get overlapping images: a blue image of the source far to the left, overlapping a green image not-quite-so-far, etc, overlapping a red image to the right. However, those bits in the middle (where multiple colours overlap) appear white, so your result is a picture of the original source (still white) except with a blue edge on the left of the source's light areas, and red on every right-edge.
what you're describing is the the basis for why goethe rejected Newton's theory in 1810 -- goethe believed that the spectrum was a compound phenomena which could be explained by the simpler phenomena of colour arising at light-dark boundaries.
from his experiments, he arrived at different conclusions than Newton. he thought that colour arises from the interaction of light and dark -- he (like you) observed that when a light area borders a dark area -- blue violet results; and when a dark area borders a light area -- yellow-red results.
goethe observed that with a prism, yellow-red colours arose along the top light-dark boundary, and a blue-violet edge arose along the bottom dark-light boundary, and that the spectrum with green in the middle only arose when when the beam of light was made small enough for these coloured edges to overlap.
it doesn't fit in with Newton's theory (who held that colour was comprised of particles/corpuscles moving at different speeds), or with young and fresnel (who held that colour was a result of different wavelengths). but the fact can nevertheless be demonstrated by experiment.
for more information, check out the goethe's 'theory of colours' (MIT Press).
  • · Replies 40 ·
  • · Replies 207 ·
16K
  • · Replies 20 ·
  • · Replies 21 ·
