Integration with a rational expression
The discussion revolves around the integration of rational expressions related to the rates of people entering and leaving an amusement park, modeled by the functions E(t) and L(t). The problem requires finding the total number of people who have entered the park by a specific time, using the integral of the function E(t) and considering the context of the park's operation hours.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss various methods for integrating the function, including factoring, logarithmic integration, and the challenges of applying u-substitution. Some suggest completing the square and trigonometric substitution as alternative approaches. There is also a focus on understanding the implications of H(t) and H'(t) in the context of the problem.
Participants are actively exploring different methods for integration and clarifying the meanings of the derived functions. Some guidance has been offered regarding integration techniques, and there is an ongoing inquiry into the interpretation of the results in relation to the park's operations.
The functions E(t) and L(t) are valid only for the hours between 9 and 23, and the initial condition states that there are no people in the park at t = 9. The discussion also touches on the importance of understanding the relationship between H(t) and its derivative H'(t) in the context of the problem.
Rawr
The rate at which people enter an amusement park on a given day is modeled by the function E defined by:
E(t) = 15600/(t² - 24t + 160).
The rate at which people leave the same amusement park on the same day is modeled by the function L defined by:
L(t) = 9890/(t² - 38t +370).
Both E(t) and L(t) are measured in people per hour and time t is measured in hours after midnight. These functions are valid for 9 < t < 23, the hours during which the park is open. At time t = 9, there are no people in the park.
How many people have entered the park by 5:00 pm (t=17)? Round your answer to the nearest whole number.
This problem is actually quite simple. I know I need to take the integral of that function and then solve for C using the information they give me, then plug 17 into the integrated equation.
The only problem is.. integrating that equation is difficult.
I know I can factor out the 15600 in E(t) to get
15600
1/(t² - 38t +370).
Then...
15600 x ln |(t² - 38t +370)| (because the anti-derivative of 1/x is ln |x|)
That is where I am stuck right now. I know that that isn't the full, complete answer, because if I take the derivative of that equation to check, it doesn't match, because of the chain rule. Am I going about this the wrong way? I don't see any other method, because u-substitution doesn't work, long division won't help, and I don't see how I can break down that equation any further.
I would REALLY like to avoid guess-and-check unless that is the only absolute way I can solve this (which I doubt).
Thanks to any help.. =)
Try completing the square, and then using a trigonometric substitution (the tangent function would be the one to choose here.)
Ahh the anti derivative of 1/x is ln |x| only when x is a linear function. When its another function, in this case t^2 - 38t etc etc, the antiderivative is different.
Try cristos method, or partial fractions.
Ah, thank you very much for that tip. That worked out much better.
Now, I have a different question. It says that...
H(t) = [PLAIN]http://upload.wikimedia.org/math/a/6/8/a68014a267c9e7ec058affc9f338d7f2.png(from[/URL] 9 to t) (E(x) - L(x)) dx for 9 < t < 23. The value of H(17) to the nearest whole number is 3725. Find the value of H'(17), and explain the meaning of H(17) and H'(17) in the context of the amusement park.
Could someone point me in the right direction on how to solve this?
H(t) is the number of people in the park at a time t in the park. H'(t) is the rate of people leaving/entering the park in that hour. Solve for H(t).
The derivative of the difference between people leaving and entering.. gives you the rate of people leaving and entering?
That does not make much sense to me.. seeing as it's the difference between the two.
  • · Replies 105 ·
13K
