Calculus involving accln and vel
  • Thread starter Thread starter sidrox
    Calculus
The discussion revolves around a particle moving rectilinearly with a deceleration that depends on its velocity, described by the equation a = α√v, where α is a positive constant. The original poster seeks to determine various aspects of the motion, including the time taken to come to rest, the distance traveled before stopping, and the conditions at which the velocity is a quarter of its initial value.
  • Participants explore integration techniques to solve the differential equation derived from the motion's acceleration. Some question the setup of the equations and the assumptions about the initial conditions, particularly regarding the initial velocity.
There is active engagement with multiple interpretations of the equations involved. Some participants have provided guidance on how to approach the integration, while others are clarifying the correct form of the equations. Progress is noted, but there is no explicit consensus on the final approach or solution.
Participants are working under the constraints of a homework problem, which may limit the information available and the methods they can use. There is an ongoing discussion about the implications of the initial velocity being v1 rather than 0, which affects the integration limits and the resulting equations.
sidrox
A point moves rectilinearly with a deceleration whose modulus depends on the velocity v of the particle as
a=(alpha) X (square root of velocity v),​
where alpha is a positive constant. At time t=0, the particle has initial velocity v1.
Then, what are the following:
i. Time taken by the particle to come to rest
ii. The distance traveled before it stops
iii. The time at which the instantaneous velocity is (v1)/4
iv. Distance traveled at the time the velocity becomes (v1)/4.
I tried to integrate the equation but ended up no where because of the v term in the given equation, which kept getting in my way...PLEASE HELP!
I want to learn how to solve such problems which involve such variables in their equations...
Writing x' and x" for dx/dt and d^2/dt^2 (Latex takes too long!)
Your equation is x" = ax'^2
The "trick" for solving this is to substitute y = (1/2)x'^2
y' = x'x"
x" = y'/x' = (dy/dt) / (dx/dt) = dy/dx
So the equation becomes dy/dx = 2ay.
No, the equation is NOT x"= ax'^2: it is x"= -a sqrt(x').
(negative a (or alpha) because you are told that the deceleration is given by alpha sqrt(v) where alpha is a positive number.)
I would have done it just slightly differently. Your base equation is
[tex]\frac{dv}{dt}= -\alpha \sqrt{v}= \alpha v^{\frac{1}{2}}[/tex]
That's a "separable" equation- you can write it as
[tex]v^{-\frac{1}{2}}dv= -\alpha dt[/itex]<br /> <br /> That should be easy to integrate. Once you have solved for v(t), of course<br /> [tex]v= \frac{dx}{dt}[/tex]<br /> so you have a second integration for x(t).[/tex]
[tex] <br /> Hmmm...i got the idea...<br /> but my problem now is how to apply the limits...on integrating, what i got was:<br /> <br /> [tex]2 \sqrt{v} = \alpha t[/tex] <br /> <br /> <i hope the latex is right, i am using it for the first time!<br /> <br /> now for the above equation, what will my limits be and where do i bring in the v1 term?[/tex]
Progress!
[tex]- \alpha \sqrt{v(t)}= \frac {dv}{dt}[/tex]
[tex]- \alpha t = 2 \sqrt{v(t)} + 2\sqrt{v(0)}[/tex]
[tex]- \alpha t = \{2 \sqrt{v(0)}[/tex]
The above is because the velocity is 0 (in the first sub division of the question)
and thus,
[tex]t = \frac {2 \sqrt{v(0)}}{\alpha}[/tex]
Now how do i proceed?
Yes, [itex]t = \frac {2 \sqrt{v(0)}}{\alpha}[/itex] is the time until the particle comes to rest (v= 0).
Now, since you know that [itex]- \alpha t = 2 \sqrt{v(t)} + 2\sqrt{v(0)}[/itex] you can solve that equation for v(t): [itex]2\sqrt{v(t)}= -2\sqrt{v(0)}- \alpha t[/itex] so [itex]\frac{dx}{dt}= v= (-\sqrt{v(0)}-\frac{\alpha}{2}t)^2[/itex].
is this true??
[tex]\frac{d}{dt} \-v(0) = 0[/tex]?
is that right?
okay...here is my working:
[tex]2 \sqrt{v} = - 2\sqrt{v(0)} - \frac {\alpha t}{2}[/tex]
On squaring,
[tex]v = v(0) + \frac {\alpha^2 t^2}{4} + \sqrt{v(0)}\alpha t[/tex]
On writing v as [tex]\frac {dx}{dt}[/tex], and then integrating:
[tex]x = 0 + \frac {\alpha^2 t^3}{12} + \frac { \sqrt{v(0)} \alpha t^2}{2}[/tex]
and i am going to continue in a separate post becos i am new to laTex and i hope all that i have typed isn't a mess...:rolleyes:
Now the body comes to rest at
Thus, i substituted the above expression for 't' in the expression for 'x'.
and i have gotten the following value for x, but it is not one of the options.
i got:
[tex]x = \frac {8 \sqrt{v(0)}^3}{3 \alpha}[/tex]
Where am I going wrong?
You were NOT told that the initial velocity was 0! You were told
You have determined that
[tex]2\sqrt{v(t)}= -\alpha t+ C[/tex]
Taking t= 0 [itex]2\sqrt{v1}= C[/itex]. That gives
[tex]2\sqrt{v(t)}= 2\sqrt{v1}- \alpha t[/tex]
squaring that equation,
[tex]4 v(t)= 4 v1- 4\sqrt{v1}\alpha t+ \alpha^2 t^2[/itex]<br /> <br /> The particle will "come to rest" when that is equal to 0.<br /> <br /> Now you have<br /> [tex]v(t)= \frac{dx}{dt}= v1- \sqrt{v1}\alpha t+ \frac{\alpha^2}{4} t^2[/itex]<br /> <br /> That should be easy to integrate for x(t).[/tex][/tex]
  • · Replies 18 ·
