Solving the Winch Problem at 12m High
  • Thread starter Thread starter dontdisturbmycircles
    Winch
The problem involves a winch at the top of a 12-meter high building pulling a pipe vertically. The winch pulls in rope at a rate of -0.2 meters per second, and the task is to find the rates of vertical and horizontal change at a specific height of the pipe.
  • The original poster attempts to set up a relationship between the variables using an equation involving the Pythagorean theorem but expresses a lack of sufficient information to solve for all variables. Some participants suggest using the law of cosines to find the angular rate of change before determining the rates of change of the horizontal and vertical components.
Participants are exploring different methods to approach the problem, with one noting a successful calculation of the rates after reconsidering the angle used in their setup. There is an ongoing examination of the signs associated with the rates of change, indicating a productive direction in the discussion.
There appears to be some ambiguity regarding the correct signs for the rates of change, as participants are questioning their assumptions about the angles and relationships between the variables.
A winch at the top of 12 meter high building pulls a pipe of the same length to a vertical position. The winch pulls in rope at a rate of -0.2 meters per second. Find the rate of the vertical change and the rate of the horizontal change at the end of the pipe when y=6.
http://www.imagehosting.com/out.php/i249658_ahhh.JPG
I simply don't have enough information..
I set up an equation relating the three variables..
[tex]s^{2}=x^{2}+(12-y)^{2}[/tex]
and differentiate with respect to time and end up with
[tex]s\frac{ds}{dt}=x\frac{dx}{dt}-(12-y)\frac{dy}{dt}[/tex]
But I simply don't have all of the variables needed. I can solve for x (with pythagorean theorem), but not dx/dt...
Any help is appreciated.
Hint:
First find the ANGULAR rate of change by a smart law of cosines.
THEN, find the rates of change of (x,y) by using a right-angled triangle.
Thankyou arildno :smile:
I was able to get the correct numerical answer but something is bothering me...
Take the angle made at the top of the wall to be [tex]\theta[/tex]...
We know that [tex]\frac{d\theta}{dt}[/tex] must be positive since the angle is tending towards 90deg right?
I got [tex]\frac{d\theta}{dt}=\frac{/sqrt{3}}{80}[/tex]... but this leads to something that is incorrect. Because when I set up the following equation to relate x and s, I get this..
[tex]sin\theta=\frac{x}{s} = x(s)^{-1}[/tex]
[tex]cos\theta\frac{d\theta}{dt}=x(-1)s^{-2}\frac{ds}{dt}+s^{-1}\frac{dx}{dt}[/tex]
which eventually leads to
[tex]\frac{dx}{dt}=s(cos\theta\frac{d\theta}{dt}+x*s^{-2}\frac{ds}{dt})[/tex]
Now, solving for x using the right triangle at the base, [tex]x=\sqrt{12^{2}-6^{2}} = 6*\sqrt{3}[/tex]
and s=12 by similar reasoning
Then [tex]tan\theta=\frac{6\sqrt{3}}{6}[/tex]
[tex]\theta=\frac{\pi}{3}[/tex]
So solving [tex]\frac{dx}{dt}=s(cos\theta\frac{d\theta}{dt}+x*s^{-2}\frac{ds}{dt})[/tex]
I get [tex]\frac{dx}{dt}=\frac{\sqrt{3}}{15}[/tex]
Which is the correct magnitude, but the incorrect sign... :/
Well, I used the lowest angle, with the variable length s(t) as the opposite side. I didn't calculate it through, but my signs looked good.
Ok, let me try that and see if I can get it to work.
Wow it worked very smoothly using the lower angle... Correct sign and all. I'll have to think about this problem for a bit. Thanks again.
