Calculating x-Coordinate Change of Moving Particle
  • Thread starter Thread starter Rasine
    Change Particle
The discussion revolves around a particle moving along the curve defined by the equation y=(17+x^3)^(1/2). The original poster is trying to determine how fast the x-coordinate of the particle is changing at a specific point, given that the y-coordinate is increasing at a rate of 4 cm/s when the particle is at the point (4,9).
  • Mathematical reasoning, Assumption checking
  • The original poster attempts to differentiate the curve equation with respect to time to find dx/dt but encounters difficulties in arriving at the correct answer. Some participants question the role of the y-coordinate value of 9 in the calculations, while others clarify its significance in relation to the function.
Participants are exploring different interpretations of the problem and the relevance of the given values. Some guidance has been offered regarding the differentiation process and the relationship between the variables, but there is no explicit consensus on the correct approach or solution.
There is an ongoing discussion about the necessity of the y-coordinate value in the context of the problem, with some participants expressing confusion about its application in the calculations.
Rasine
a particle moves along the curve y=(17+x^3)^1/2. as it reaches the point (4,9) the y coordinate is increasing at a rate of 4 cm/s. how fast is the x-coordinate of the point changing at that instant?
so dy/dt=4 cm/s
i diffeientate the curve equation with respect to time to get
dy/dt=(3x^2/2(17+x^3)^1/2)dx/dt
i want to find dx/dt so i put 4 cm/s in for dy/dt and 4 for x (given by the point (4,9)) and then i solve for dx/dt, but i am not coming up with the right answer. please tell me what i am doing wrong.
What did you get?
dy/dt=d((17+x^3)^1/2)/d(17+x^3) . d(17+x^3)/d(x) . d(x)/dt
4=1/2.(17+64)^1/2 . 48. dx/dt
72/48=dx/dt
or dx/dt=1.5 cm/s is what i expect you should have got...
I don't understand how to use y=9 ?
y=9 is a necessarily given value, due to the function relation.
yeah, but how does one use it? Or is it just given...
It was a nice gesture of the exercise maker to provide the actual y-coordinate.
besides, remember that the derivative of y wrt. to x can be written as:
[tex]\frac{dy}{dx}=\frac{3x^{2}}{2y}[/tex]
i think 9 was just given as to give the point with the x-coordinate .
i got the right answer by the way.
thank you for your help.
